Need a little help from the experts!
Old Aug 3, 2012 | 12:12 PM
PolskaSax's Avatar
Hi everyone, I know this is a diesel forum, but I figure its probably the best place to get help. Ive searched all over and cant find any solid info on my truck. Its a retired air force truck from Utah. The guy I bought it from said it was a 1Ton single wheel. However on the title it says its a D250. So my questions are, do you recognize the running gear? Since im going to make this my pipeline truck, I want to make it a dually. Is it as simple as buying dually studs and wheels and installing them on this axle, and if it is, is this axle capable? I appreciate the help!
Old Aug 3, 2012 | 12:38 PM
cougar's Avatar
A D250 is a 3/4 ton, not a 1 ton. Sense it is a gasser it has a Dana 60 axle. I believe the 70 was used in the single rear wheel 1 ton models and the 80 was used in the duallies.
Old Aug 3, 2012 | 02:06 PM
PolskaSax's Avatar
I was told that Dodge would put 1ton gear under 3/4T's, if the customer requested it I was curious if they did that with this truck. I cant find anything stamped on the housing to tell me if its a 60, or 70.
Old Aug 3, 2012 | 02:35 PM
simplysmn's Avatar
That's a 3/4 ton Not a 1 ton Air force is good at that they just put a flatbed on what ever they have handy to convert it you would need a 1 ton dana 70 or even a dana 60 drw axle then adapter's for front PM me if you need the front stuff
Old Aug 4, 2012 | 07:35 AM
Philip's Avatar
Thats a 9 1/4" corperate axle. Its close to the same strength as a 60. But they are noted for pinion bearing problems.
If you listen close to any gasser Dodge trucks/ Vans on the road. If you hear a singing rear axle. Its a 9 1/4.
Old Aug 4, 2012 | 08:29 AM
hounddogks76's Avatar
How many miles are on it? That is one clean truck underneath.
Old Aug 4, 2012 | 08:30 AM
WOW !
How sweet is that frame !
Not a speck of rust on it at all .....
Old Aug 4, 2012 | 09:28 AM
dodgenstein's Avatar
That is definitely a Dana axle.
Old Aug 4, 2012 | 10:05 AM
Flake's Avatar
Definitely not a 9 1/4, for one thing it's full floating, two it has a Dana60/70 cover.
Old Aug 4, 2012 | 10:36 AM
PolskaSax's Avatar
I looked up pics of the 60 and 70, and they look the same to me. They say theres a casting mark to the left of the right axle tube, just on the housing. Cant find it. Im in the process of sanding it and painting. Yesterday I rhino lined the rear of the cab, painted the frame a little more, and installed a leveling kit. It has 83,XXX mi.
SSminnow
26
Jul 10, 2011 09:08 AM
DodgeDemon
Jun 30, 2007 01:44 PM
NoSparkplugs
Aug 2, 2006 03:35 PM
sled4fun
May 13, 2006 02:18 PM
JW3
Mar 15, 2006 08:23 PM
