Gun experts, I need your help
Old Aug 1, 2006 | 10:12 PM
NoSparkplugs's Avatar
Question Gun experts, I need your help
Ok, I've got an old Cooey Model 600 .22 and its in fairly good shape. The only problem I have with it is that I can't figure out how to get the bolt out? It makes it a pain to clean since I can hit it with the bore brush and then oil the action and barrel. There must be a trick to pop the bolt out?
Thanks
Old Aug 1, 2006 | 10:23 PM
phox_mulder's Avatar
Been a while since I shot it and therefore cleaned it,
but my old Winchester bolt action .22, you just pull the trigger all the way back (I think).
phox
Old Aug 1, 2006 | 10:29 PM
gerry's Avatar
My Old JC Ohiggins (sears) has a little tab you push down...
Old Aug 1, 2006 | 11:19 PM
BearKiller's Avatar
Thanks
Can you post a picture of the receiver??
I used to be a gunsmith, by trade, and I never heard of a Cooey.
If I could see a close-up of the action, I could probably see how to get out the bolt.
Old Aug 1, 2006 | 11:21 PM
BearKiller's Avatar
I thought J.C.Higgins was Montgomery Ward, not Sears.
Someone straighten me out, if I am wrong.
Thanks.
Old Aug 2, 2006 | 02:43 AM
CTDinMT's Avatar
Bear- It's a Winchester Mod 60. JC's were sold under Sears name, among many other manufacturers. Wards were mostly Savages and Mossbergs.
No spark plugs-The Cooeys were made in Canada. The model 600 Cooey is the same as the Winchester 60. I'm also a gunsmith and have never encountered one personally, but try like was said above, to pull the bolt all the way to the rear. Try it both with the striker cocked and dry-fired. In other words, MAKE SURE THE CHAMBER IS CLEAR, and dry-fire. Now, keep the trigger held to the rear. While holding the trigger to the rear, lift the bolt handle and retract the bolt all the way to the rear. Hopefully it will come out of the receiver. I have gone through my resources at my bench, and haven't even found a schematic of the Win Mod 60, so I'm just guessing on the above advice. Give me or BearKiller a shout if it still won't come out. I'm sure one of us can figure it out.
Old Aug 2, 2006 | 12:45 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
I have a really old Cooey in my gunshop, I plan on making a trip out that way later I will see what it takes to remove the bolt. If I recall (also a licensed gunsmith) Cooey's can date back almost to the stone age
Old Aug 2, 2006 | 12:47 PM
HappyGA's Avatar
well, that ought to be well within your time table.
i feel a thrashin coming on...
Old Aug 2, 2006 | 03:27 PM
Admin Team Leader
If I didn't know any better I would think there was an insult in there somewhere
Old Aug 2, 2006 | 03:35 PM
hotdram's Avatar
That's the problem with some people when they get old, they just don't know when you are messin' with them. Takes the fun out of it
~Rob
15
Nov 11, 2007 10:09 PM
DodgeDemon
Jun 30, 2007 01:44 PM
bulthisl
Apr 14, 2004 01:04 AM
