need help with my new Hx-35/12cm setup
I finally got this thing on. Took it for a test spin, and when I brought it back the exhaust housing itself was smoking, like it had oil on it. There are no oil leaks, there is a little exhaust leak from the manifold to where the housing connects that I need to fix. Anybody have any ideas?
Thanks, Tony
Thanks, Tony
Was your hands greasy or oily when you installed the turbo? Did you use a new gasket from the manifold to the turbo? My hx came from the junkyard and the exhaust housing smoked the first time i drove it after install. If you did not use a new gasket, 4$ will get u a new one at the dodge dealer. Also a little ultra copper gasket sealer might help on that gasket too. It worked well for me on the wastegate adapter on my hx. Good luck
ez
ez
Well I got everything put on. The spool up is quicker, but not as much as I would have thought, coming from a 21cm. I'm glad I didn't go with the 16cm.
The smoke from the exhaust housing was all of the liquid wrench I put on it. lol
Any way it is a great improvement. Thanks, for all the help guys (via my threads, and all of the old threads).
Later, Tony
Any way it is a great improvement. Thanks, for all the help guys (via my threads, and all of the old threads). Later, Tony
TJE
Sep 13, 2007 10:41 AM
cumminsdriver635
50
Jan 16, 2006 11:02 AM
cLAYH
Jun 4, 2004 01:40 PM
