Need help with an 1992 4x4 auto (some info)
Old Jul 8, 2010 | 09:09 AM
roxxx's Avatar
My buddy has a 4x4 reg cab 1992 Auto
there is a canister on the Passenger side of the motor.... It is leaking tranny fluid like crazy, right at the fitting
As you can guess I haven't a clue about auto trans
Any info on what this is would be appreciated Thank you
Old Jul 8, 2010 | 09:22 AM
Subliminal's Avatar
The horizontal canister under the turbo on the block?
That's a heat exchanger. It has an in/out line from the tranny and an in/out line from the radiator.
Have you guys tried tightening up the hoses where they go in/out?
Old Jul 8, 2010 | 09:26 AM
unixcowboy's Avatar
That's the trans cooler...
It runs engine coolant in the canister and there's a tube through the inside that runs the trans fluid.
If you're leaking at a trans cooler pipe connection try carefully tightening it. At the age of these trucks, and some of the abuse they've put up with, the fitting may be too rusty to tighten and break off...
If it does you're not much worse off than now with it leaking all over.
You might find a cooler in a wrecking yard or someone here or another forum that pulled their cooler so they could get twins installed.
Or you coulg get a heavy duty aux cooler and just replace the stock one. Your temps might go up a little with only and aux cooler but it should still work.
Old Jul 8, 2010 | 09:28 AM
roxxx's Avatar
Yes that be the one and it is tight , It looks like the previous owner snagged the line and may have bent it right at the fitting
Thank you for a the name of it now i know that the heck i am looking for
EDIT : Can this be bypassed ?
Old Jul 8, 2010 | 09:34 AM
roxxx's Avatar
Thank you Would anyone happen to know if He can by a new one ?
Old Jul 8, 2010 | 10:09 PM
Rick 12v CTD's Avatar
you can buy a new one I think but they are insanely priced from dodge last I heard. I doubt you can get it anywhere else either.
Old Jul 8, 2010 | 11:15 PM
roxxx's Avatar
shoot ...... It is a daily driver and it gets cold in winter here i would like to just bypass it but probably not wise any alternatives ?
Ideas on how to make one ?
Old Jul 8, 2010 | 11:45 PM
trying to find a used one is probably your best bet. I haven't bypassed mine because it's cold here too in the winter and the heat exchanger actually makes a huge difference in warmup of the trans.
Just hit the classifieds on here and on CF. I'm sure someone has one they are willing to part with for a reasonable price.
roxxx
ABDTR #5
Nov 2, 2010 12:53 AM
roxxx
Nov 2, 2010 12:49 AM
V.R.Wheeler
Aug 4, 2007 01:00 PM
Mini_Donkeys
Apr 19, 2007 12:21 PM
Jim Weed
Sep 30, 2003 08:53 PM
