My little green Leer-Jet!
So, I finally found time to install my BHAF. I did it up like the sticky so it was super simple except when I welded the little piece of tubing backwards on my bracket
. I think im going to order a sock to help keep the filter a little cleaner out hear in the desert. So, what did I get from installing this?
1. A drop in EGTS of at least 25 degrees at my normal cruising speed.
2. @ 1.5 psi of Boost
3. Clearance for taxiing at the airport because with the stage 4, I sound like a jet!
My old filter was pretty dirty, so I was wondering if that is where my numbers may have come from?
Also, not to sound like a sissy, but is there a way to subdue the jet noise?
. I think im going to order a sock to help keep the filter a little cleaner out hear in the desert. So, what did I get from installing this?1. A drop in EGTS of at least 25 degrees at my normal cruising speed.
[QUOTE=BC847;1439841]Or install a silencer ring.
[QUOTE]
At least on my HTT housing, there's no provision for a silencer ring, but I seem to remember reading that you can ask for one when ordering...
[QUOTE]
haloman
79
Sep 10, 2006 11:59 PM
bkrukow
15
Aug 29, 2006 06:41 AM
