Moving my injector pump
I'm trying to put in a 3200 rpm spring. I have the 3 pump nuts loose, hand loose. How much pressure does it take to get the pump to move? Right now it is pretty tight not wanting to move unless some pretty good pressure is applied. I don't want to break anything.
Thanks, Tony
Thanks, Tony
If your just doing the spring there is no need to move the pump, but since you have it loose you should bump the timing buy about an 1/8". To bump you want to take a ratchet strap and hook the pump and something solid on the motor and move it up (towards the passenger side).
That is what I forgot, but it will still barely move at all.
Thanks Guys, I had to move the pump, couldn't get the passenger side rear hex nut loose. Still can't get it loose. I have the timing marked, and it is already bumped an 1/8th. All I can get the pump to move is back to stock position. I need it to go more than that.
What will give more low end, stock timing, or advanced timing?
Thanks again, Tony
Thanks again, Tony
Up Date
I finally got the top of the pump off, and the new spring is ready to install tomorrow. I have a problem though. The fuel line that goes to the front of the pump has got a hole in it. Can this be patched with a rubber fuel line?
Thanks, Tony
Thanks, Tony
TJ0993
11-08-2007 10:27 AM
silverbullet02
09-23-2005 04:09 PM
