maybe dyno he-351 tomorrow,ksb tips?
Old Jun 26, 2009 | 10:33 AM
crewcabxlt's Avatar
might dyno tomorrow in utah. does the ksb really add 20 hp? running on a superflow. any tips appreciated. thanks. hope my 6 month old clutch holds. i think it slips alittle now with he=351.
Old Jun 26, 2009 | 11:16 AM
92smokin blacky's Avatar
where you dynoing at crewcab? At moonlight or is there somethin else goin on down there? I'm not totally sure that the ksb will add 20 more horse, I've never dynoed before, but i have mine hotwired and you can tell it does advance the timing a little. When i turn it on when its idling, I can hear the idle sound change a little bit so it does advance it a little. Its pretty easy to hotwire it, just run a wire from your battery to a switch and another wire from the switch to the KSB. Good luck on the dyno, let us know how you do.
Old Jun 26, 2009 | 02:11 PM
crewcabxlt's Avatar
ive got my ksb on a toggle. the non i/c ksb is different,power to during normal driving. off for advance. hoping to dyno in provo at an event. it didnt rain enough to stop me from doing hay so i hope i can still do it.
Old Jun 26, 2009 | 04:45 PM
No power to the KSB, trans in 5th. Stand on it.
Old Jun 26, 2009 | 06:26 PM
oh i see. Yeah I just started cuttin our hay up here yesterday, and as soon as i got done with the field, it started rainin... I guess thats just how things go. Luckily we only got one field down in the rain. Well good luck man
Old Jun 26, 2009 | 08:01 PM
crewcabxlt's Avatar
thank you.
Old Jun 26, 2009 | 08:30 PM
RollinCoalSmoke's Avatar
Good luck crewcabxlt. Oh and send the RAIN this way-no rain in about 2 1/2 months and it's 102 in the shade. 107 out in the truck yard today. Hay? it's all dead for the most part around here. Anyways good luck with your dyno run.
Old Jun 26, 2009 | 09:18 PM
jesussaves's Avatar
what is KSB??
Old Jun 27, 2009 | 07:55 AM
Billut's Avatar
Originally Posted by jesussaves
what is KSB??
From a site about the VE pump (note: CSD = Cold Start Device; KSB is basically the same meaning but in Germormon):
"Another CSD, called the KSB (a Bosch designation), advances injection timing by controlling supply-pump pressure. A KSB control valvemounted on the side of the pump overrides the pressure regulator, increasing supply-pump pressure and advancing injection timing. For example, if the temperature is below the set value of the temperature switch, the switch closes and the KSB solenoid switches on. This increses pump pressure. Above a preset value, the temperature switch opens, the KSB solenoid opens, and the pressure regulator now controls supply-pump pressure."
Old Jun 27, 2009 | 04:24 PM
JQmile's Avatar
Keep us updated, also let us know what the KSB thing does, if anything. On my truck I have it off on the dyno usually "just in case."
Old Jun 27, 2009 | 10:48 PM
crewcabxlt's Avatar
364.4 hp at approx. 2600 rpm, held pretty flat to around 3000, ksb off,fuel pin (cone) on ground side. egt between 1300-1400, boost north of 40 psi. run # 2, tow/ economy set-up, 331.5 hp, same rpm range, ksb powered,fuel pin rotated to shallower side. egts 1100 + but didnt hit 1200,boost 38 psi, were its wastgated. pretty happy with numbers, i feel the ksb trick did help. on the street it felt a little better too when testing. will post more info when i get time
Old Jun 27, 2009 | 11:58 PM
good numbers man
Whats the specs on the injectors? like hole #/ size ?
Old Jun 28, 2009 | 06:54 AM
crewcabxlt good numbers & great job. When you get time and some rest give us some torque numbers also. Congrats on your truck.
Old Jun 28, 2009 | 07:51 PM
crewcabxlt's Avatar
thanks guys sarting new thread on the dyno day fun,see for details. cs- the injectors are 5 hole, guessing .0013 or .0014. got em used. run super clean . former moonlight diesel sled puller sticks, when it had ve pump. wish i new more.
92smokin blacky
Jul 17, 2012 01:33 AM
CarsonS
Apr 8, 2011 11:05 PM
Lucas1
Jan 2, 2011 10:17 PM
jogl
Jul 21, 2010 07:55 PM
59FORD
Feb 26, 2007 06:44 AM
