Marine Head Gasket - What makes it better?
Old Jun 5, 2006 | 08:24 AM
goodtyms's Avatar
Okay, it's finally time to do my head gasket. I already bought the standard replacement from Cummins, but I read where people recommend the Marine version, but no metion why. What makes it better? It it that much better than the standard one?
Old Jun 5, 2006 | 11:15 AM
bgilbert's Avatar
Clear things up
Cummins makes 3 headgaskets for the B series. Standard, .010 oversize, .020 oversize. All of which are marine headgaskets.
Old Jun 5, 2006 | 11:57 AM
blueberry's Avatar
I think the "confusion" over the marine head gasket is that early on there was a regular and also a marine gasket. As production years went on Cummins dropped the regular version, leaving only the marine version.
Regards,
Brian
Old Jun 5, 2006 | 02:24 PM
bgilbert's Avatar
Brian is right. I think when most folks talk about the 'marine' headgasket they are speaking of the .020 HG. By just slapping this HG on while not getting the head checked out at a machine shop, it will lower your compression a bit, allowing more air and fuel to be able to be pumped in. I'm sure there are some other benefits, maybe some other members will chime in.
Old Jun 5, 2006 | 04:43 PM
flashgordon's Avatar
Maybe i'm just not getting it but it will lower your compression a bit, allowing more air and fuel to be able to be pumped in.???? compression is what a diesel is all about!!!!
the only reason i would put a thicker gasket on would be if the head or bock had to be shaved! Or and i missing some trick to a high per forming diesel?
Old Jun 5, 2006 | 04:52 PM
As you raise the boost it's best to lower the compression to reduce peak cylinder pressure. Helps keep parts inside the block.
A typical pulling engine runs around 12:1 compression. That's an extreme example, but most of us would benefit from the 0.020 gasket. When mine blows it's what I'll use.
Old Jun 5, 2006 | 05:00 PM
Thanks dave!!!!! if i would have used my gas turbo mind, i whould have allready fig that Ya, i new that
Old Jun 5, 2006 | 06:31 PM
mhuppertz's Avatar
I know that you can get lower compression marine pistons that have a deeper dish for better flame propogation and control. But thicker head gaskets are cheaper!
Old Jun 6, 2006 | 01:10 AM
bgilbert's Avatar
Thanks Dave for jumping in there and helping me explain myself . I will do the same if my 90 or 91.5 ever need a HG.
Old Jun 6, 2006 | 10:01 AM
fast 5.9's Avatar
The Cummins part numbers to use are
3283335= stock thickness
3283337= .010" oversize
3283339= .020" oversize
pwrtripls1
Mar 10, 2011 12:12 PM
adidasman23
14
Apr 8, 2007 08:47 AM
Conn
Dec 29, 2006 06:30 AM
rambod
Dec 5, 2006 03:22 PM
INJECTOR JACK
Oct 20, 2004 08:32 PM
