Magic Book
Old Jul 26, 2005 | 03:44 PM
fearthedeere's Avatar
Smile Magic Book
Got my cummins manual today and started tearing the thing a part. I got some questions its kinda vague. Do i need to take my rockers and valve springs out. And do i have to remove my injectors.
Old Jul 26, 2005 | 03:52 PM
You can leave the valves and springs in, but you should pull the rockers off. The injectors don't have to come out, but it's a good idea to pull them so you don't damage the tips if you bump something or set the head down on them.
Old Jul 26, 2005 | 04:53 PM
Thanks, i was doin good on the manifold got all the top bolts loose real easy and started on the bottom ones they were comin easy too this the 5th one its looks like its been rounded off. or somethin cuz the socket wont go on it. grrrrr.
Old Jul 26, 2005 | 06:37 PM
swank's Avatar
i agree with dave on pulling the rockers. and most definitely pulling the injectors. it is VERY easy to to snap a tip off one of those suckers. i'd leave that manifold on there if you've got an engine hoist to use. and everything else for that matter. just valve covers, head bolts, injector lines, and the various sensors. be careful with the small bolts on the rockers too. before you put it all back together, try to find a tap to run through the holes. i wish i would've done that. i had one break right above the head surface. almost took a sledge to the windshield when that happened. i'll be replacing all those next time i have the head off. anyway, good luck and have fun.
dave jr.
Old Jul 26, 2005 | 09:48 PM
Begle1's Avatar
So what are you doing? I'm lost...
Old Jul 26, 2005 | 10:09 PM
gman07's Avatar
Where have you been all this time?
FTD blew the headgasket on his truck
Old Jul 27, 2005 | 09:16 AM
yea im makin too much powa It is a learning proccess ive learned that when im workin if any one comes in with a blown headgasket im tellin em to go do emselves.
Old Jul 27, 2005 | 10:24 AM
Micaiahfied's Avatar
how far have you gotten?
Old Jul 27, 2005 | 03:36 PM
not far, one bolt the manifold is off. ill really tear into it soon as i get the gasket.
bgoodwin
Dec 1, 2005 03:55 AM
Geico266
Feb 4, 2005 09:18 AM
Racer57
Nov 15, 2004 01:07 AM
wheezer
May 6, 2003 10:33 AM
gramps
Jan 20, 2003 10:35 AM
