M&H... M2 or M3 for daily driver
Old Dec 2, 2013 | 12:40 PM
sdseva's Avatar
Im going to order the dynamic timing device and a fuel pin and was hoping for some input.. i would guess that the 4 and 5 pin are a little excessive for a DD? How smokey is the 2 and 3 pin versus the stock? Controllable? Noticeable performance gains with the pin/spacer combo?
Old Dec 2, 2013 | 02:25 PM
Rick 12v CTD's Avatar
Most people don't know it but you can grind a stock pin for a custom ramp and still have full afc travel/fueling that will be seen with an aftermarket like Dennyt or m&h
Sent from Tapatalk 4 via a Galaxy S3
Old Dec 2, 2013 | 02:43 PM
cougar's Avatar
If you worried about smoke, stick with the stock pin. Too easy to get fueling a head of boost and start smoking.
Old Dec 3, 2013 | 03:19 AM
jimbo486's Avatar
I ran the M3 in my original pump. I had the starwheel run up to flush with the threads on the bushing and ran the stiffest spring I could find at a fuel injection shop. Which, ultimately, still isn't much stiffer than the original. I don't know at what pressure the pin starts to move but it's probably around 10psi. And with the Super 40/35, boost came on fairly quick but what smoke I did see before it spooled, cleaned up well. It's all in how you tune the AFC.
I would say it was a mild amount of smoke for a manual but I could control it with my right foot. Under light acceleration I hardly saw much smoke. I had enough on stand-by for those times when anybody wanted to follow me a little too close.
Old Dec 3, 2013 | 05:27 AM
MARF75's Avatar
I had a similar question I just emailed to M&H and in their reply they stated that they're all out of M2,3,4 and 5 pins and it would be months before they had more.
Just an FYI.
Old Dec 3, 2013 | 08:12 PM
Oh wow. How about that....
CTD_Neil
18
Nov 7, 2005 09:18 PM
bharring
Apr 29, 2004 02:55 PM
kingofdodge7131
Aug 31, 2003 12:20 PM
hellotbone
16
Nov 6, 2002 03:18 PM
