Lube
Old Aug 27, 2009 | 10:07 PM
Cory's Avatar
Lube
I need to change my lube in my Transmission and Transfer case. They are in my 1989 Dodge Cummins truck. What is the best to use? I like AMSOIL. Do I just use regular 90w gear lube or what?
Old Aug 27, 2009 | 11:21 PM
SOOT4BRAINS's Avatar
Pod Boy (on hiatus)
Transfer case
-90w gl-5 or use 80w gl-5 if used below -10 degrees. uses 4.5 pints
Auto tranny
-ATF type 7176 or Dexron type 2 if ATF 7176 is not available uses. 8.4 quarts
Getrag 5 speed manual
-5w30 motor oil, synthetic is recommended. I use redline MTL synchromesh fluid, others use royal purple and amsoil synchromesh fluid and like it.
-uses 3.5 quarts, but overfilling it a quart will help it live a longer happier life
Old Aug 29, 2009 | 05:53 PM
sdseva's Avatar
hey guys, just a quick question. what is the EASIEST way to overfill the getrag? Im not the most auto savy guy but i can get some things done. Oh and one more, can i get amsoil from your everyday parts house like napa or car quest? thanks
Old Aug 29, 2009 | 06:04 PM
1985cucv's Avatar
i use ams in everything on my new one
Old Aug 29, 2009 | 07:58 PM
u.s mma's Avatar
I pull the shifter out, make sure its not in gear when you do. Im fixing to put some RP in the tranny soon, got 75-90 in the tcase with all them shiney happy new bearings.
Old Aug 30, 2009 | 07:41 AM
Street elbow in the fill hole.
Old Aug 30, 2009 | 09:24 AM
ofcmarc's Avatar
Close, He's 4x4... Gotta go around the T-case linkage.
Old Aug 30, 2009 | 01:35 PM
sdseva's Avatar
helpful pic. thanks. so after i get that all set up, do i just shimmy a bottle up there and carefully pour in until i have an extra quart in there? and then i just leave that sweet elbow up there?
Old Aug 30, 2009 | 01:52 PM
That's what I do. I use a small funnel to reduce the chance of spilling.
Old Aug 30, 2009 | 08:31 PM
Richie O's Avatar
366 Spring Chicken
Thats all well and good but how do you guys check the level?? I just fill in the top pto cover bolt till it comes out.
Old Aug 31, 2009 | 08:46 AM
ofcmarc's Avatar
I pull the T-case shifter boot and use a tranny funnel.
Gonna rig up a dip stick shortly. A piece of threaded rod through the fill cap outta do.....
Old Aug 31, 2009 | 06:37 PM
A nifty custom dipstick. It's a piece of coat hanger bent into a "J". You check the level by hanging it over the edge of the elbow (makes it repeatable) and then pulling it out. I marked the stick when I filled the trans.
Old Aug 31, 2009 | 06:46 PM
sdseva's Avatar
genius...now i just need a job so i can pay for all this!
Old Aug 31, 2009 | 07:17 PM
Richie O's Avatar
366 Spring Chicken
Nifty. That would work.
Old Aug 31, 2009 | 07:21 PM
Riflemanusmc's Avatar
Registered user
+1. Pull the shift tower out. Put it in N before you do. As long as you have no leaks/no worries...
mknittle
Mar 11, 2015 10:47 AM
dssimecek
Mar 10, 2008 04:58 PM
commando
Mar 16, 2003 08:51 PM
pwabbott
31
Dec 4, 2002 09:09 AM
Superduty12v
Oct 14, 2002 10:31 AM
