LP fitting sizes?
Old Sep 2, 2010 | 07:11 AM
jeff77indy's Avatar
LP fitting sizes?
What are the fuel line fitting sizes on a diaphragm LP?
Thanks
Jeff
Old Sep 2, 2010 | 10:24 AM
BearKiller's Avatar
Thanks
Jeff
Diaphragm or recommended piston-lift-pump :
TOP = OUTLET = 14MM x 1.5 ( a common tapered 1/4-NPT WILL easily screw into these threads and I managed to accomplish this leak-free after several attempts before I knew better, it's best that you get the proper metric fitting )
BOTTOM = INLET = 1/4-NPT ( it works fine, but I sort of suspect that this fitting might just possibly also be 14mm x 1.5 metric; most everyone has used the NPT fitting here )
Seeing as there are about a bejillion different part-numbers and applications for the CARTER piston-lift-pump, and many of these applications have nothing to do with a Cummins, I would assume that the inlet/outlet fittings on many of these are liable to be just about any size/thread imaginable.
morkable
ABDTR #5
38
Nov 4, 2009 07:51 PM
mdavlee
Oct 16, 2008 02:29 PM
SMOKNISB
Oct 8, 2006 08:02 PM
trik396
Mar 4, 2006 04:51 PM
