Low idle when hot
Low idle when hot
Since the warm weather is back the low idle problems are back too. After a run on the freeway, when I come to a stop in gear (auto) the RPMs will drop to 500 or lower causing the engine to shake and sometimes the oil idiot light to come on. At a stop I have to put it in neutral or 2 foot it (briefly). Low speed parking requires 2 footing it. This happens even with a cold idle RPM of 850. Got any ideas on how to fix this? Oh, this is without using AC.
Thanks
Thanks
I would try adjusting the idle up a bit, but its my understanding that it may be a worn pump... pump head to be exact...Ive got a similar problem. Im seriously looking at one of those Roken-tec(?) 14mm pump heads to slap on there.
Wonderful!
I've already lived with it for awhile - every summer! When i've saved enough money to get a new one, what mods should I do or have done to it? Is there any way for a shade tree meckanik to rebuild it?
Im willing to bet they just screw the power screw in and add a BD fuel pin then charge you out the wazoo for it. Plus the "cheapest" one they have is 2300
i think they are actualy a 14mm head unit with a higher lift plunger. about $700 to upgrade a stock pump to those parts. I guess I could go with a good rebuilt pump or new pump and upgrade. I should have kept the other marine VE I had that was rated at 230hp. It probibly already had those parts. lol
