low boost ????
Old Jun 3, 2009 | 05:37 PM
dodgethis91cmns's Avatar
low boost ????
today i was driving and realized that for some reason my truck seems to have low boost numbers and high egts. i was crusing at about 45 at 1-2psi of boost and around 500-600 degrees. pulling a slight grade i got up to around 700 degress and a steep long grade around 800. this was all dont in valet mode and with a SLOPPY SLOPPY converter. just curious to know if that sounds OKAY?
Old Jun 3, 2009 | 05:38 PM
It shouldn't make much boost just cruising along. The EGT sounds fine too.
Old Jun 3, 2009 | 05:40 PM
thanks dave. hopefully after the trans is in which will me very soon it woll lover the egts by just a tad bit
Old Jun 3, 2009 | 08:07 PM
archer39's Avatar
your egts and boost should go up after the trans. You will be putting a load on the engine unlike the sloppy 727.
Old Jun 3, 2009 | 08:15 PM
ahhhh zach that makes sense. becasue it will actaully be putting more power to the ground. right now i cant get my pyro past 1000
Southtowns27
Jul 2, 2011 08:50 PM
jmlcolorado
May 19, 2010 10:30 PM
Moobesor
Feb 23, 2008 09:57 AM
daveg
13
Feb 1, 2008 11:05 PM
