"lopey" below 1000rpm
Old Jul 16, 2006 | 11:34 PM
silverbullet02's Avatar
After I put in the DDP stage 3's I got from piers, under 1000ish rpm, it kinda has a little lope like a gasser with a little cam surge. Get 'er above that and smooth as silk. Could that be from running a little too much timing? Currently at 1.9mm. Kinda odd, cause it never did that before. Any ideas? Thanks!
Brian
Old Jul 17, 2006 | 02:49 AM
bgilbert's Avatar
What size injector washers did you use? Maybe you're spraying outside the piston bowl on one or two cylinders?? Mine is smooth as silk, and I'm sure I'm well above 1.9mm.
tweeter123
Jun 12, 2011 09:15 PM
Roque
Jan 4, 2011 10:47 PM
spitzair
Jul 20, 2010 08:43 PM
Mikestowing
37
Mar 10, 2009 09:05 PM
dougdanger
Mar 5, 2007 08:13 PM
