loose brake caliper fix?
Old Jun 2, 2013 | 08:33 AM
MARF75's Avatar
I have an annoying rattle over bumps. I believe I've narrowed it down to the sloppy calipers.
I've heard you can buy an oversized wedge and spring kit to take up the slop but I was wondering what anyone else has done to cure this problem. I'm tempted to add some material ( bead of weld) to the caliper mount and grind flat.
I've also heard of swapping to Chevy calipers. Has anyone done this? Do you need just the calipers and mounts or the whole outer, including hub, spindle and rotor?
I had a Ford 60 once and they were so sloppy they would fall right off and hang from the brake hose. I tack welded the wedge in on that one, it was an off road only truck though.
Thanks for any input and advice.
MARF
Old Jun 2, 2013 | 09:53 AM
diesel402004's Avatar
Hey Marf75. I just re-arched the spring in the caliper and that solved the problem. It did come back a little after about 10K. But re-arched one of them again and no problem since.
Old Jun 2, 2013 | 10:06 AM
BILTIT's Avatar
I replaced the calipers in mine, helped alot.
Old Jun 2, 2013 | 10:51 AM
93-12Smoke's Avatar
Never thought of this bring the cause of my annoying rattle/clank over bumps. I'm going to have to check that
Old Jun 2, 2013 | 11:23 AM
bobva's Avatar
Yes chevy 1ton do interchange with the 4wd trucks. dont know about 2wd
Welding,, you can buy brand new unloaded raybestos calipers for 48$ at RA
Old Jun 2, 2013 | 11:32 AM
MARF75's Avatar
I meant welding on the caliper MOUNT itself. I've already replaced one caliper and its the loser of the two.
As far as welding on the mount, now that I think of it, is that cast?
Old Jun 2, 2013 | 11:34 AM
MARF75's Avatar
Originally Posted by diesel402004
Hey Marf75. I just re-arched the spring in the caliper and that solved the problem. I did come back a little after about 10K. But re-arched one of them again and no problem since.
Is there any special technique to it? Heat and bend? Or try to roll it?
Old Jun 2, 2013 | 12:08 PM
bobva's Avatar
Have you seen this https://www.dieseltruckresource.com/....php?p=3165733
Old Jun 2, 2013 | 12:47 PM
MARF75's Avatar
Originally Posted by bobva
Thanks bobva!!
Good read. Gonna try to inspect mine today!
Old Jun 2, 2013 | 06:19 PM
Because it's spring steel, I had to clamp it to the bench and use a little heat and force. I didn't move it much, but it added more force to hold the caliper in place and solved the rattle. Obviously bobva's link showed the ultimate rebuild fix, but happy with my temporary fix.
Old Jun 2, 2013 | 07:01 PM
MARF75's Avatar
I bent the spring on one side today but yet to test drive it as time was a little scarce today.
I put the spring, arch up, over a piece of 3/4" round stock then grabbed a pair of good ole 2 position adjustable pliers, spread the handles of the pliers out to lock in behind the little tabs on the spring, and gave the tip of the pliers a couple wacks with a beater. Hillbilly?? maybe but it worked, time will tell for how long. Thanks diesel!
Old Jun 2, 2013 | 07:32 PM
93-12Smoke's Avatar
What about a new spring. Kit available from the part store for $11
Old Jun 2, 2013 | 07:34 PM
MARF75's Avatar
That's always an option too! Haha
Old Jun 7, 2013 | 06:37 PM
MARF75's Avatar
After further inspection, the passenger side spit out the spring and the wedge was half way out rubbing the inside of the wheel. So two warrentied, reman calipers will be mounted tomorrow because the seal around the piston is shot. They were replaced 11/15/11 and already shabby!
As for the rattling, loose caliper. Im thinking its the inner pad rattling.
The little clips were missing on one side and the other side had one, that the tab was worn off of. So ill report back after reassembly with the clips on the inner pads and new/ reman calipers.
Once again thanks for the help guys.
Hey 93-12, check out your inner pads and let me know what you discover.
Old Jun 10, 2013 | 02:11 PM
MARF75's Avatar
Rattle fixed!
It was the inner pads.
uglydukwling
Feb 9, 2009 07:58 AM
Leaky Gasket
Aug 14, 2008 07:17 AM
jerky1280
Sep 10, 2005 10:22 AM
PurdellMGP
Aug 12, 2003 02:19 PM
berner
Feb 9, 2003 07:37 PM
