light flicker
Old Aug 24, 2009 | 09:18 PM
dodgethis91cmns's Avatar
light flicker
i just noticed this about 5 minutes ago when i pulled in my driveway. i pulled in and turned just my parking lights on so my headlights werent shinning in my windows and the parking lights keep my pyro still lit and i wanted to let it cool down a bit before i killed it. i looked out the windsheild and noticed my lights were kind of flickering a little bit. what would be causing this?? i was thinking something along the lines of a voltage regulator, but im not electrically savy so figured id turn to the pros
Old Aug 24, 2009 | 09:55 PM
Free89W350's Avatar
My truck does it to. My uncle said it has done it from new and no one could firgure out what it is. Once you give it a little trottle it goes away and the lights are smooth. I would also like to figure mine out.
Old Aug 24, 2009 | 10:10 PM
its so faint thats why it kind of tipped me off that something might be wrong
Old Aug 24, 2009 | 10:45 PM
BearKiller's Avatar
That is a common Dodge syndrome, usually caused by the voltage regulator.
You can replace the regulator with the Blue Mopar part-number that is listed in my "sig" and the flickering will go away.
Old Aug 24, 2009 | 11:18 PM
Dumb question, is the voltage regulator on the firewall up by the cowl?
Old Aug 24, 2009 | 11:19 PM
And will leaving it hurt anything out of curiousity
Old Aug 25, 2009 | 04:35 AM
BearKiller's Avatar
Yes, located almost directly over the center with a triangular-shaped two-wire plug.
So long as the alternator is charging properly, leaving it as is shouldn't hurt anything, so long as the flickering lights don't end you up in the crazy house.
rebel_horseman
Jan 16, 2011 06:03 PM
smokeyram
Oct 16, 2007 05:26 PM
jerry007
Feb 18, 2005 02:39 PM
vbert
Jan 29, 2005 02:35 AM
Eagle Driver
Feb 20, 2004 06:39 AM
