Lift Pump Issues
Old Mar 23, 2014 | 06:25 PM
209trucker's Avatar
Lift Pump Issues
Hey guys. My cousin and I just installed the 3200 gov spring in his 91.5 auto 4x4. Got it all back together and tried firing it and realized the 5mm hex screws for the cap had come a little loose so it was leaking fuel. Tightened three of them back up, one was still tight, and put it back together. Tried firing it again and no dice. Cracked #1 injector and it was getting a tiny tiny bit of fuel. Cracked #2 and it was less than #1. Went to the lift pump, the lever doesn't pump back up. Could these symptoms mean the lift pump went bad? Thanks for any input.
Old Mar 23, 2014 | 06:37 PM
aicomp's Avatar
Sometimes you need to turn the engine over e slight amount to get the ramp on the lift pump on the cam properly.
Mike
Old Mar 23, 2014 | 06:48 PM
209trucker's Avatar
I bled the bleeder for the pump and it brought prime back to the lever but when my cousin tried cranking it it lost its prime. We'll try turning the engine over a little bit
Old Mar 23, 2014 | 07:09 PM
209trucker's Avatar
Tried turning the engine over a tad and still nothing. When the lift pump lever is down and we try to crank it, the lever will come back up. But when we try to prime it again the lever stays down.
Old Mar 23, 2014 | 07:51 PM
aicomp's Avatar
Sounds like a new pump is in order. I have gone through a couple in 465,000 miles
Old Mar 23, 2014 | 08:03 PM
209trucker's Avatar
I was thinking the same. I just thought it was weird that it went out now after we had just changed the gov spring. He said he doesn't remember the lever ever having prime.. I wasn't sure if the truck would still be able to start or not without a proper lift pump? We just took the VE pump back apart to make sure we didn't do anything wrong and everything on that side of it seems fine. When I cracked the bolt for the lift pump I was able to get a little little bit of fuel out of it. But when I had my cousin try turning the engine over with it cracked it sent out plenty of fuel.
Old Mar 23, 2014 | 11:08 PM
aicomp's Avatar
Lift pumps are cheap. I would replace it. Just my $.02
Old Mar 24, 2014 | 11:31 AM
cougar's Avatar
Getting all of the air out of an injection pump can be a real pain. Just need to keep at it. Crack all of the lines at the injectors and keep bleeding.
If you decide to do a lift pump, save yourself some effort and go with a low pressure piston lift pump.
Old Mar 24, 2014 | 05:39 PM
209trucker's Avatar
Well, the fulcrum lever was broken. I don't remember seeing in the write up to pull the fuel screw out all the way, or even part of the way. But in the video it said to back it out until you see the o ring which my cousin and I did but oh well. We'll be putting in a new VE pump in a couple days. Thanks for the help though guys!
Txwelder
Nov 26, 2025 01:53 AM
TRCM
Jul 29, 2019 11:07 AM
Txwelder
May 19, 2005 06:10 PM
dhe9
Oct 18, 2003 12:28 PM
