Lift pump install
Old Dec 26, 2011 | 02:12 PM
sootnsmoke's Avatar
Lift pump install
Looks pretty straight forward but have never done one on this truck. Any tips? Looks like some guys replace the 2 bolts with studs and say it is much easier to mount up. Not sure on that. Looks like I will just need to open the bleed screw, pump the lever and purge air after install. Any other words of experience from those that have done this. BTW, I am installing a new Carter/Federal Mogul stock pump from Napa
Old Dec 26, 2011 | 02:41 PM
BC847's Avatar
1st Generation Admin
A general "How-To" . . . https://www.dieseltruckresource.com/...ad.php?t=93722
Old Dec 26, 2011 | 03:12 PM
sootnsmoke's Avatar
I am glad I read your write up as I didn't think about those 2 sealing washers for the bango bolt. I take it that I should not be reusing my existing ones even though I am not changing to the piston pump with new steel fuel line, correct? With the stock pump type connections, using a thread sealer is required?
Txwelder
Nov 26, 2025 01:53 AM
BC847
Apr 29, 2019 10:35 PM
caper
Apr 16, 2006 01:45 PM
Txwelder
May 19, 2005 06:10 PM
GSP
Oct 13, 2004 12:35 AM
