leaky IP
Ive got a leak coming from what appears to be the back side of my ip ,block side firewall end of the pump.Isnt there an o-ring in there famous for giving up? Where is a rebuild kit available?
Sounds like the big o-ring around the pump head. You can replace that while on the truck if you get some bolts @ 10mm longer than what is in the head. You can slowly back out the head until you see the o-ring and get it out with some picks. The kit is the dk-121, check the other pump threads to make sure of that....
There is also an O-ring located on the opposite side of the KSB-valve that can't be seen or serviced with the pump on the engine.
The best thing is to study all the excellent threads on re-sealing the pump; then, pull the pump and replace EVERY seal.
If one is leaking, it is only a matter of time before more start.
It seems like extremely cold weather will also start leaks that are borderline.
Thanks again Mike
I just got the pump out about an hour ago. I haven't worked on a diesel before and just wanted to see what it looks like. I pulled the back off of the pump to find the o-ring with some cracks in it. Cummins parts dept is closed today so I'll try again tomorrow.
Randy
Randy
