Timing bump ?
Old May 26, 2008 | 06:56 PM
maxx250's Avatar
Timing bump ?
I was over at troutman69's (Randy's)today and helped him pull the IP off his truck,before we took it off I noted that the timing marks on the pump/timing case were lined up ,would it be a benifit or would you guys recommend bumping the timing an 8th or so when we put it back together?Thanks
Old May 26, 2008 | 06:58 PM
Sure, might as well. Most trucks pick up a little MPG with a timing bump.
Old May 26, 2008 | 07:01 PM
maxx250's Avatar
Cool ,how about the fuel screw? Would you go ahead and put a turn or two on it while its off.It has quite obviously never been tinkered with before,the sleeve is still on there.
Old May 26, 2008 | 07:03 PM
Not unless he has a pyrometer.
Old May 26, 2008 | 07:07 PM
maxx250's Avatar
Roger that,I know hes bought the pod but dont know if hes got the gauge yet
Old May 26, 2008 | 07:28 PM
99globalwarmer's Avatar
bump the timing a tooth that will help and if its to much adjust with pump
royta
Nov 6, 2006 08:19 AM
LCH
Oct 26, 2006 05:10 AM
GR40RCapri
Jun 25, 2006 12:53 AM
ouchman
Feb 15, 2006 04:47 PM
LanceD
Oct 25, 2005 11:16 AM
