Leaking PODS
Old Mar 22, 2008 | 12:17 AM
bigragu's Avatar
Leaking PODS
Any POD users suffering from leaks? Ever since I switched over to PODS, I have had leaks coming up from the injector port. It is ever so slight, but enough to bug me. I have had them for 6 months now, and they leaked when I 1st put them in, so I yanked them out and re-did every step. I used the .020 washers, and already have re-torqued them a second time. I did everything by the book on the install. My BD 40 hp injectors that I used to have never leaked, and I used .020 washers on those, too( I used new ones when I switched over to the PODS). What gives? BTW, it is only #2, 3, 4, and possible #5 that dribble.
Old Mar 22, 2008 | 06:21 AM
77machomopar's Avatar
I had the same problem. I just went through and cleaned the injector ports extremely well. I also torqued them down a little more then the factory specs.
Old Mar 22, 2008 | 07:26 AM
Did you use an injector bore brush to clean? A small hose taped onto a shop vac nozzle does wonders for getting the loose crap out when you are done brushing. The leak is due to crud under the copper.
Old Mar 22, 2008 | 05:01 PM
Trebor's Avatar
If it's not a dirt problem then it could be cylinder head cracking in the injector bores.
Old Mar 22, 2008 | 06:53 PM
roxxx's Avatar
yes i was going to say cracked head too. how many are leaking?
bad injector maybe have them tested on a bench
lilsuzuki4x4
Sep 1, 2011 01:50 AM
bigragu
Aug 2, 2007 03:41 PM
atc250r
15
Sep 15, 2005 01:39 PM
jec3
50
Mar 23, 2003 10:00 AM
Mopar_Mudder
Nov 16, 2002 01:30 PM
