Leaking fuel from the injector pump
Old Mar 5, 2006 | 12:19 PM
dfwguy5150's Avatar
Hi all, New here and need some help. I have a 1989 dodge diesel and have noticed a fuel leak. Looking at the pump from the driver side fender I see a small rubber overflow tube?? on the backside of the injector pump. This is on the right side of the pump or you could say the firewall side. I removed the rubber tube and I can now see (with a mirror) a square silver piece with a brass middle with a small pinhole size area in it. This only leaks while running. Can this be tightened? Does it need replacing? Expensive fix???? HELP!
I hope I described this in a way you can understand!
Thanks, Heath
Old Mar 5, 2006 | 01:11 PM
torquefan's Avatar
The problem would have to be internal. The piece you refer to is a vent, and there shouldn't be fuel in the area behind it. Tightening it won't help. Hopefully someone else can tell you what the actual repair is.
Old Mar 5, 2006 | 01:25 PM
G1625S's Avatar
Most likely culprit is the AFC pin's 'o' ring. Lemmie go look at mine to see how much of a pain it is to replace.
BTW--welcome to DTR!
greg
jesussaves
Jun 28, 2012 01:36 PM
truckdweld
Oct 29, 2011 03:52 AM
Jambbii
Nov 5, 2004 10:59 AM
yomitch
Apr 21, 2003 06:28 PM
