Leafs again..
Old Jul 13, 2012 | 01:41 PM
bannerd's Avatar
Leafs again..
So I put my springs in.. feels like the front end is going to blow out.. is there a procedure? I torqued them to 90ft/lbs and then drove it around and re-torqued. Maybe it's just bad shackles?
Old Jul 13, 2012 | 02:24 PM
BILTIT's Avatar
Define what you mean "the front end is going to blow out".
Old Jul 13, 2012 | 03:27 PM
bannerd's Avatar
Kind of has a sway to it from side to side. I used the stock shackles and bolts in my new leaf springs. The ones they sent me were not the best material.
Old Jul 13, 2012 | 08:18 PM
BILTIT's Avatar
Did you torque the spring eye bolts with the wheels on the ground (weight on the springs)?
Old Jul 13, 2012 | 10:32 PM
bannerd's Avatar
Negative i did it on the lift.
Old Jul 13, 2012 | 11:01 PM
U-bolts tight? Sounds like the springs are walking side to side which is pulling on the steering.
Old Jul 13, 2012 | 11:53 PM
93flatbed's Avatar
Do what he said^
Old Jul 14, 2012 | 08:33 AM
BILTIT's Avatar
With the truck on the ground, loosen all spring eye bolts and bounce on the bumper a few times to be sure everything is moving properly and can settle out to its normal position. Re-torque all spring eye bolts. Be sure to check the u-bolts after some use aswell.
Old Jul 14, 2012 | 08:44 AM
j_martin's Avatar
Make sure you haven't hosed the alignment. Toe in way off can cause some weird things to happen, especially with wide tires.
Old Jul 14, 2012 | 09:58 AM
Lifted Spring, or stock height ? Lifted springs change your caster, and can cause "squirrely" handling.
You're over torquing the shackles. They're supposed to be maxed out @ 80 ft lbs. The U-bolts and axle bolts on the passenger side are 90ftlbs, and the front spring eyelets are 100 ft llbs As said in other recent threads, the weight of the vehicle is supposed to be on the springs / axles before final tightening.
https://www.dieseltruckresource.com/...d.php?t=304378
Drive it around for a few days then re-torque. U-bolts are designed for an "initial stretch" when installed. All spring manufacturers advise to replace u-bolts after one install, and for the $9 -$15 a piece, it's worth the $$ for peace of mind. There have been situations where other members have had the u-bolts snap after installing them a second time.
Old Jul 16, 2012 | 05:56 AM
bannerd's Avatar
Thanks guys, I'll have tighten them on the ground. The springs are parabolic and they ride about the stock height. I need to get rear springs, when I jack the rear up the steering wheel goes back to normal. Must be some pressure on the steering gear.
Old Jul 16, 2012 | 10:31 AM
j_martin's Avatar
.... or negative caster. Wheel alignment.
Old Jul 16, 2012 | 01:57 PM
BILTIT's Avatar
4wd has no adjustment for castor so an alignment will do nothing except double check toe setting. Spring shims are needed to adjust castor if that is the problem.
Old Jul 16, 2012 | 04:52 PM
I believe that you can also order a specialized set of king pins that allow offset to correct caster as well.
It's almost never really needed.
Old Jul 17, 2012 | 06:19 AM
kiszka6911's Avatar
There are degreed special spacers that go behind the axle flange mounts that can adjust this.
MoPowa
Jun 18, 2010 07:44 AM
Steven K
Jun 4, 2009 10:32 AM
b84u
Feb 20, 2006 01:04 PM
mr T
Mar 12, 2004 05:58 AM
