Latest update
Old Jun 20, 2007 | 09:57 AM
pokeypennell's Avatar
Latest update
Well most of you have read my other posts about melting my powersteering pump shaft and the havoc that it caused. It continues but with a happy ending.
So finally got all the parts assembled, 2 new vac pumps the PS pump. I pressed the gear housing assembly together at my house using a wooden wedge to aid in the process, work quit nicely to a point when I broke off the ear that holds the vac pump on, no biggey I got that welded. So the gear seemed like it need to go on a bit further so I brought it to the local napa to have them press it. They guy couldnt press it any further! So I took it home and attempted to press it in further with the above method, seemed like it was working well until the bolt broke off in the gear. So I attempted to drill and extract the bolt, but it wont budge! So i decided to throw the thing back in and reasembled it last night. The old beast fired right up after sitting for nearly 2 months! I ended up breaking one of the wires for the H20 sensor that goes on the fuel filter. Does anyone know how much these cost??
Old Jun 20, 2007 | 11:46 AM
jjdiesel1990's Avatar
those lil buggers are expensive being as there only a little plastic and a couple wires. mine was 45$ from dodge.
Old Jun 20, 2007 | 11:54 AM
Ouch, that is expensive for what it does!
Old Jun 20, 2007 | 03:52 PM
Micaiahfied's Avatar
all the wire does it turn the light on in the cab. the seperator is still functional. just drain it a little every once in a while and it should never be a problem
Old Jun 20, 2007 | 04:27 PM
Geno's Garage has the WIF sensors for around $25 I think. It's a Fleetguard part, so check with Cummins before you give Dodge $45.
cstewart
Oct 8, 2012 04:32 PM
LooseBoltsRob
Dec 13, 2006 12:25 PM
Jim Lane
Dec 29, 2004 10:36 PM
MnTom
Aug 25, 2004 11:19 PM
95ramtough
14
Oct 14, 2002 11:14 PM
