ksb, questions
Old Oct 24, 2008 | 09:49 PM
Alwaysworking's Avatar
alwaysonDTR
ksb, questions
alright, since i blew wnother head gasket on my white truck i swapted engines to a 92 intercooled one with some mystery injectors and such, but what do i need to do about the ksb?
should it be hot all the time or not?
Old Oct 24, 2008 | 10:52 PM
89f150's Avatar
on the intercooled motor its just used to start
Old Oct 24, 2008 | 11:02 PM
alwaysonDTR
so i guess i need to figure out a way to keep power away from it, except when its cold?
Old Oct 24, 2008 | 11:26 PM
gear jammer 91"'s Avatar
A lot of guys just wire it to a switch.
Old Oct 24, 2008 | 11:33 PM
alwaysonDTR
but it needs no power except when cold right?, that is what i need to know
Old Oct 25, 2008 | 12:37 AM
CTDreul's Avatar
what will happen if the ksb has power all the time
Old Oct 25, 2008 | 12:50 AM
Tron's Avatar
The Ksb hot wired gives it more fuel and more advance. It ups the pump head pressure from what I understand. If you put it on a switch use it to start as if it were a choke, have it on till warm or turn it off right after start up.
Old Oct 25, 2008 | 01:03 AM
89f150's Avatar
no if it has power all the time itll burn it up
Old Oct 25, 2008 | 03:18 AM
IRoss's Avatar
On the IC motors the ksb is activated by power from the IP, unlike the non-IC where it is powered constantly and activated by loss of power...in either case, while activated, it increases case pressure in order to increase internal advance during warm-up (as far as my understanding goes) and over-enthusiastic use is not recommended
Old Oct 25, 2008 | 10:10 AM
ofcmarc's Avatar
12 v only when needed. (cold start or drag/dyno) Off at all other times. There is a thermal switch in the back of the head that controls it automaticaly but a manual switch works well also. The power for the switch does come from the IP shut down solinoid but any 12v keyed source will work.
Old Oct 25, 2008 | 11:22 AM
alwaysonDTR
okay thanks, i just put a switch in it since i used all the non intercooled wireing on the intercooled engine, so i dont think there is anything telling it to turn off.
Diesel Jeff
Apr 19, 2014 07:14 AM
wheelo90
Aug 31, 2013 04:55 PM
92smokin blacky
Jul 17, 2012 01:33 AM
59FORD
Feb 26, 2007 06:44 AM
getblown5.9
Dec 23, 2005 10:22 AM
