Killer Dowel Pin
Old Mar 1, 2012 | 05:23 AM
nolafishr's Avatar
Killer Dowel Pin
Did the first Gen Trucks have this problem with the dowel pin? I am sure they did.
I am asking because I am not sure if my truck had it fixed or not. I will be taking the front end cover off soon to inspect and fix it. I want to be sure of this and have a piece of mind knowing it is done.I will also inspect my radiator and change out the coolant and thermostat. I would rather do all of this at one time. Does anyone know the Torque on these bolts for the front cover when putting this back together?
Old Mar 1, 2012 | 07:51 AM
Exekiel69's Avatar
Yep, You need to kill the KDP.
Old Mar 1, 2012 | 08:31 AM
ppiggppenn's Avatar
While you're at this, it's not hard to pull the rad for easier access for the KDP work. My experience with rads is "when in doubt, replace the rad".
Old Mar 2, 2012 | 04:19 AM
nolafishr's Avatar
I will be pulling the Radiator to do this, it makes it easier and gives you more room.
I did find out the torque for the front cover bolts
Old Mar 3, 2012 | 08:26 AM
339K&Counting's Avatar
Rad is easy to pull
Makes the KDP much easier
I don't remember the torque but is around 20 ft lb +/-
Don't go ape on them
Cheers
rush47
14
Mar 16, 2006 06:55 PM
Abbynormal
Mar 9, 2006 07:53 PM
Abbynormal
16
Mar 8, 2006 09:03 PM
Greguw
Oct 16, 2005 01:25 PM
Holycack
Jun 25, 2003 02:16 PM
