key swich
you might try inserting it like this
(from repair manual)
1. make sure truck is in park (if auto)
2. with key cylinder and ignition in lock position, insert cylinder into ignition switch assembly until it bottoms.
3. Insert key, push inward on key cylinder, then rotate key clockwise to end of travel.
4. check each position
This assumes that your lock is not wore out. There is a pin that normally has to be depressed in order for the lock to be removed. If that or other part have worn then a replacement is in order.
jmccart
13
Oct 1, 2008 09:39 PM
rkelley
Oct 20, 2006 05:55 AM
big red psd cc
Dec 29, 2004 11:38 PM
