Keep an eye on those rear spindle nuts...
Old Jul 1, 2008 | 12:18 PM
1tondodge's Avatar
While on a road trip towing to a rockcrawling comp down in Bend, OR I had my driverside rear spindle nut back off on the D70. Luckily I was on a backroad going slow when it happended because the whole hub, wheel, and axle assembly started to come out. Thank god I wasnt on the freeway. I had never had the rear end apart was surprised that it was just a single nut, unlike any FF axle I had worked on before. Luckily Baxters had the bearings and seal, got a GM 14bolt spindle nut from a friend and was able to patch it up on the side of the road. I will definetly be converting both sides to the double nut and locking tabed washer set up because I dont trust the factory setup anymore! Dodged a bullet with this one...
Old Jul 1, 2008 | 01:11 PM
BRUISER's Avatar
I keep extra spindle nuts in my truck..
Old Jul 1, 2008 | 04:06 PM
Philip's Avatar
Someone left the lock wedge out sounds like.
Old Jul 1, 2008 | 08:41 PM
Trebor's Avatar
Anybody know the N number and the W number that fits the front and rear spindles on our trucks? Various sizes are shown on this page:
http://www.precspec.com/lockwashers.htm
Old Jul 2, 2008 | 01:40 AM
BearKiller's Avatar
Wink Here Is The Good Stuff
http://quad4x4.com/Dodge%20Rear%20Axle.htm
I despise those soft steel single-nuts.
I have yet to see one that the bearing didn't cut a groove in, thus loosening the bearing adjustment.
I have NEVER had a locking-tab-washer double-nut system do this.
Old Jul 2, 2008 | 09:06 AM
1tondodge's Avatar
I was looking at a couple of your older posts yesterday and came across that link. at work we are a dana dealer and I was able to dig through some old boxes and find all the parts listed in their kit. I will post part numbers this afternoon...
Old Jul 2, 2008 | 05:25 PM
bgilbert's Avatar
Excellent, I'm waiting.
Old Jul 3, 2008 | 04:20 PM
Trebor's Avatar
I would also like to file those Dana part numbers away for future references.
Old Jul 13, 2008 | 12:38 AM
1tondodge's Avatar
Well its been a bit but after extensive searching the components I thought would work ended up being for the smaller spindle D60. I was able to locate a new stock nyloc hex nut but not the nuts from the quad 4x4 site. I wasnt able to find the parts in the reference books either.
Old Jul 13, 2008 | 10:06 PM
BearKiller's Avatar
Originally Posted by txs
if your bearing is eating your axle nut sounds like the tabbed washer is missing that goes between the inner race and the nut.
I have removed dozens of dozens of those nuts/bearings and have NEVER found a washer of any type between the nut and bearing.
Do you have a picture ??
Thanks.
Old Jul 14, 2008 | 08:29 AM
bgilbert's Avatar
Thanks.
Same here, all of mine have never had the ugly washer behind them. But after reading this, I went ahead and installed the ugly washer behind the nylock nut on a brake job this weekend. I had a pair laying around.
Old Jul 14, 2008 | 04:11 PM
FSM and the parts book both show the washer. I guess a lot of folks leave them out.
Old Jul 14, 2008 | 09:28 PM
rovingbenz's Avatar
Old GM 14 bolt nut and snap ring works on the 1989 rearend but I cut new keys from 1/4 inch stock. The GM keys seemed too loose to me.
Ryan
Old Jul 14, 2008 | 10:49 PM
BearKiller's Avatar
Can I see a picture, please ??
j_martin
Jun 10, 2015 07:45 AM
Mexstan
16
Mar 13, 2011 12:58 PM
Bookshelf
Feb 9, 2008 01:33 AM
Dave88LX
Nov 5, 2005 07:22 PM
