Kdp
Now that you bring it up, I looked at my 93 last night and the area around the pin has a different shape than my 96, making me wonder how it should be fixed. It seems like the bolt closest to the pin location is further back in the case than the boss the pin goes through. This is different from my 96, where I just tabbed it with a modified fender washer. I did feel better that the pin has not moved at all, so far.
I have an 89, 91.5, and this 93 that all may need fixing, so instructions on the best way to do this will be appreciated. I'd like to tab it, since it does not require a jig that is required to pin it.
Thanks,
Chris
Thanks,
Chris
Well the pin is far inside and seem like it never moved in 200k miles and what I did was drill a hole and tap it then drive a flat head stainless steel screw to stop it from falling.
Now what happened here is something I'm not really proud of but the screw ended further away from the pin than I planed
. So... I wanted to know how long is this pin in case it moves the screw will stop it anyway. I know I'm an idiot, is looks perfect but I wish it where just a bit closer.
sootnsmoke
Jan 5, 2012 08:55 PM
.....from your description it sounds fine to me.
