Is it just me or is my truck noisy?
Old Mar 1, 2007 | 09:57 AM
MikeThomas's Avatar
Going from a Tundra to the ol' Dodge is definitely a change. I guess I havent been around the old 12v enough to know if my truck sounds normal. To me there is an awful lot of clicking and ticking and more clicking. I know mechanical valves are always kinda noisy (I even adjusted mine), and its going to have the "diesel" noise, on top of what I expect to be a lift pump going out the window...so......Tell me guys, am I normal? Are all of our trucks noisy? Ive tried a straight pipe, but I can still hear it!
Old Mar 1, 2007 | 09:59 AM
BRUISER's Avatar
YUP, they are very very noisy..
I have tried alot to quiet it down , and still no luck..
Old Mar 1, 2007 | 11:16 AM
Boatnik's Avatar
That ain't noise. It is sweet sound of perfection and prescison. Music to my ears
Old Mar 1, 2007 | 11:40 AM
89dieselkong's Avatar
You'll get used to it. After awhile it'll be the quietest thing you've ever been in (that'll be to the hearing loss )
Old Mar 1, 2007 | 11:53 AM
93beater's Avatar
my truck is the same way, i have to crank up the radio to hear it over the awesome 12v drone and the clanks!
Old Mar 1, 2007 | 12:30 PM
Ace's Avatar
Ace
It was a little unnerving to me at first, too. But after awhile, and knowing the truck is healthy, I've gotten used to what it sounds like. A little different under cetain throttle positions, deceleration, and various rpm at these conditions, etc. I think in the long run that will make it easier to spot truly "ab"normal noise.
Old Mar 1, 2007 | 12:53 PM
ppiggppenn's Avatar
my "noise" (music to my ears too) stops almost completely when I get off the pedal so I'm thinking combustion noise accounts for much of my clangs and clicks. 'Course there are those valves still needing adjustment, er when I get to it ....lol
Old Mar 1, 2007 | 02:27 PM
jdwest's Avatar
Heck, I thought I was in heaven when I went from an over-valved truck to this one. I actually think the first gens are the best sounding of the bunch, just loud enough and not too quiet like the third gens. My 24-valver always sounded like it rattled a little too much, even with the valves set with in specification. I know there was nothing wrong with it....it's just the nature of the beast. I love the way first gens they bark to life when first started!! Music to my ears...followed by a big black "puff"!!
Old Mar 1, 2007 | 04:08 PM
pred's Avatar
I have 300+k miles, and when the valves are adjusted to factory spec, There is no valvetrain noise that i can hear over my 4" straight piped truck.
Engine, well YES, valve clatter NO
Old Mar 1, 2007 | 04:17 PM
Layton's Avatar
My truck has recieved a body swap from e/c to reg cab long box. There is no insulation on the firewall so there is quite a drony noise in the cab. The pipe is also straight and the tires are big ugly things that throw stones. So I think that all of this accounts for some of the noise. i am going to try and find some bulk rolls of 1" insulation that I can try and stick it to the firewall to kill some of the engine noise.
Other than that this thing purrs like a Cummins.
Old Mar 1, 2007 | 04:30 PM
What?! You'll have to speak up, I can't hear you over this noisy truck!
Old Mar 1, 2007 | 04:39 PM
BC847's Avatar
1st Generation Admin
Originally Posted by MikeThomas
Going from a Tundra to the ol' Dodge is definitely a change. I guess I haven't been around the old 12v enough to know if my truck sounds normal. To me there is an awful lot of clicking and ticking and more clicking. I know mechanical valves are always kinda noisy (I even adjusted mine), and its going to have the "diesel" noise, on top of what I expect to be a lift pump going out the window...so......Tell me guys, am I normal? Are all of our trucks noisy? Ive tried a straight pipe, but I can still hear it!
I'm running a huge very quiet muffler with the companion resonator in the four inch exhaust, along with a TAG-III (essentially includes the silencer ring) in the turbo fed by a totally sealed air intake.
I've got 5/16" thick shredded rubber under all the floor covering with 3/8" thick RubaTex (foam rubber) on the side and back cab walls as well as the doors. The interior roof has 1/2" RubaTex.
Ignoring the turbo shrill, . . . . the engine is loud with mechanical sounds.
Especially with 38psig of alcoholic breath!
Old Mar 1, 2007 | 04:42 PM
Terraizer's Avatar
I went from a 99 24 valve (still have it) to my 1993 12 valve and to me the 93 is quieter. Now the 99 rides and handles a ton better then the 93 but it is also alot more $$ to repair and seems to need work more often then the 93.
Old Mar 1, 2007 | 06:00 PM
whereswaldo250's Avatar
Took me a while to get used to my truck clicking and ticking, but its great
Old Mar 1, 2007 | 07:28 PM
JD730's Avatar
I find my 2000 is the same way, loud, rattly, more expensive to keep on the road, stupid VP.
