Jake brake bad?
Jake brake bad?
I am looking at a truck, its a 1992 250, 92,000 miles 5 speed 3.55 limited slip. Truck looks really good, no rust, etc. It said 1 older owner, and very well maintained. With all the garage on it, i believe it was 1 owner. It has a Boost guage, Pyro, and a Tach.
It also has a Jake brake. are these good or bad for the engine?
What you refer to as a jake brake is actually an exhaust brake. The exhaust brake mounts on the backside of the turbo or downstream in the exhaust piping and uses a butterfly valve or gate controlled by a solenoid to actuate the valve or gate. A jake brake on the other hand is oil actuated and solenoid actuated to hold the exhaust valves open at compression.
You might want to check with the owner to make sure heavier 60lb exhaust valve springs were installed with the brake installation.
The exhaust brake has been tested and used for years and comes as a stock item on almost all medium duty trucks that run the ISB, B model, C7, MB engines.
wvcowhauler
13
Apr 3, 2005 11:39 PM
KenR
Jan 10, 2003 07:10 PM
