Its alive!! sort of
Old Sep 29, 2005 | 11:53 AM
skchevota's Avatar
Its alive!! sort of
Well I fired up my 70 chevy that I droping the 93 cummins in, I did not have the inercooler hooked up yet , but it was a test fire. She started right up and sounded good, for about 30 seconds, then sputterd and died. I hit the blead off on my fuel filter and she sucked in a bunch of air. I gess I will have to drop the tank. I have a pump in the tank from the LT1 I removed, I was hopeing it would pull fuel through the pump but I gess not, it will if I manuely pump it but not when it is actualy running... My 4" exhaust sounded sweet though!
I have a small oil leak that appers to be coming from one of the rear pan bolts, I replaced the pan gasket while it was out , I did not notice or check
are the rear bolts through holes? if so I did not seal the threads.So I started to hook up the inner cooler last nite , found a good use for the stock 3" down pipe! Do you know on the 3" ruber couplers , do they make them in 90s or 45s ? I will keep you guys updated.
Old Sep 29, 2005 | 11:59 AM
Tiny's Avatar
Congratulations, ought to be an awesome truck when you are done. I have always liked that generation Chevy truck, sounds like quite an undertaking.
Old Sep 29, 2005 | 12:13 PM
andyr354's Avatar
cool.
What model of chevy 2wd, 4wd, 10, 20, ect...
Once again, really would like some pics when you get a chance.
Old Sep 29, 2005 | 12:30 PM
apwatson50's Avatar
Yes they do make those couplers in 45 and 90deg.
Old Sep 29, 2005 | 03:14 PM
skchevota's Avatar
Its a C20 witch has been converted to 4x4. It has a 3/4 ton 10 bolt front with disk brakes, dana 60 rear , lockers , 4.56 gears 37" ssr raidial tires. ... where could I find the couplers, are they factory.
Old Sep 29, 2005 | 03:48 PM
http://www.hightempsilicone.com/
A good place to find the angled boots.
As long as the pump in the tank doesn't put out more than 15-20 psi, you could use it to feed the engine if you wanted.
Old Sep 29, 2005 | 03:50 PM
apwatson50's Avatar
He said its a lt1 pump, which if its for the EFI lt1, than it probably puts out at least 40psi.
Old Sep 29, 2005 | 04:46 PM
skchevota's Avatar
Yea, EFI it was around 55psi with the regulator, without Imsure its higher. how about an inline regulator, if I kept it around 15 psi, would a gas syle pump last with diesel fuel. If I did that should I keep the mechanical lift punp?
Old Sep 29, 2005 | 04:47 PM
skchevota's Avatar
Also , would a gas sylle regulator work?
Old Sep 29, 2005 | 04:49 PM
You could use a regulator. If it was me I'd ditch the in - tank pump. The mechanical pump is simpler and they rarely give any trouble. Also you don't need much electricity to run the truck - nice if the alternator dies.
Old Sep 29, 2005 | 07:30 PM
lovemysan's Avatar
I can vouch for this I drove my truck 3 weeks hotwired, before I realized the alternator wasn't charging.
blownsmoke2
Aug 14, 2007 07:18 AM
Bobcat698
May 19, 2007 05:57 AM
65fury
Mar 6, 2007 09:39 PM
dig'umz
Sep 17, 2005 08:04 AM
SilverDodge
Aug 6, 2004 03:43 PM
