IP question
IP question
Not to sound like more of a newbie than I already am but here goes...I have turned my Full Fuel Adjutment Screw in one turn. I was told by a diesel mechanic that it will raise the fuel pressure of the VE and that he has blown one up by turning that screw too far in. If it does raise the pumps pressure, how far is too much and I was just wondering what was safe and what wasn't. Also I was wondering if there is major power in this pump tweak...Any help will be appreciated and once again thanks for not being too hard on the newcomer
It does not raise the fuel pressure. It does increase the effective stroke of the pump plunger, though, and that puts more load on the cam ring and rollers. Make sure you run some sort of lubricity additive (Stanadyne, Power Service, or even 2 stroke oil) to keep the pump happy.
The main fuel screw is the most power you can get for free.
I am on a budget right now as I am a high school student, so is this mod recommended because i know you all at least can save the money to put into a pump rebuild. I definitely love to see that power and would not be opposed to doing it, but what is a safe amount of turns where large amounts of stress are not being put on the cam lobe?How many rebuilds have yall had on your pumps?would you recommend this mod knowing that I dont have a whole let to spend at the time being.....?
Hey guys thanks alot for that info on the fuel screw i turned it in a turn and a half more and i hit 30 lbs of boost for the first time and i am pretty excited.thanks again everyone i cant wait to get the governor springs in.
mkeanglorldo56
Nov 4, 2007 12:34 PM
Murf
Aug 17, 2007 04:36 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
