Intermittant VERY low Oil pressure at idle after hard pull
Old Apr 23, 2006 | 03:45 PM
HappyCamper's Avatar
OK Guys, here's one for the gang.
My '91 D350 Dually 2wd ran well over the past week. Took it on a road trip towing a 24' Travel Trailer with 2 ATV's on the bed. Pulling into Los Alamos up a steep grade in 3rd gear. I pulled over to sight see, shoved in the clutch and let idle. The idle dropped lower than normal, and the oil pressure gauge bottomed out and and the warning light came on. I pressed on the accelerator a little, popped up the idle to a fast idle (by sound) and the oil pressure jumped up and the warning light went out.
This happened an additional two times over the week, each after having run the truck a little harder than normal. Other times, after a hard run, it behaved like usual.
Just before the trip, changed the oil (rottella) and filter (STP). The oil has remained at full with normal appearance and feel (slick).
I have plans to add additional gauges, but have not felt the need for them yet as the truck has not been BOMB'd.
Any suggestions would be appreciated. (BTW - Fuel mileage ranged from 14 - 19 mpg towing depending on headwind, grade and how hard I was in it)
Old Apr 23, 2006 | 03:47 PM
First thing I would do is change the sender. This sort of thing happens fairly often, and a new sender clears it up.
Old Apr 23, 2006 | 04:12 PM
flashgordon's Avatar
I sec. it. Replaced the pump pressure spring,turned idle up(which helped temporarly) replaced pressure sw and now I idle itdown evan lowerthen before with out any problems I would start with sw.!!!!
Old Apr 23, 2006 | 04:15 PM
Thanks, I felt that it probably was a sensor/electrical due to the fact that under load it performed as expected. Any way, a new sender is a cheap place to start.
Rich
Old Apr 23, 2006 | 04:17 PM
edwinsmith's Avatar
Where is the pump pressure spring located?
Old Apr 23, 2006 | 04:22 PM
In the filter mount. It's under a plug near the front on top of the mount. Remove the plug and the spring is directly underneath.
Rarely gives any trouble.
Old Apr 23, 2006 | 05:09 PM
goodtyms's Avatar
I had the same thing happen to me at the top of a high mountain pass. I really struggled between beleiving the gauge and shutting it down or let it run long enough to cool the turbo. I kept it running...
Old Apr 23, 2006 | 05:28 PM
Yeah, freaked me out for a moment, then realized that with a little pressure on the 'go-juice' the oil pressure came up. The water temp was looking good so I only worried a bit. I learned somewhere in the past that stopping an engine after a hard pull up a mountain is hard on engines... something about all that excess heat just boiling the oil and warping heads.
Rich
klx650a2
Oct 14, 2010 09:18 PM
Thedieselkid
Dec 19, 2007 03:01 PM
allmountainbike
Sep 11, 2007 09:11 PM
Ilikebikes
Nov 29, 2006 06:07 AM
hdwrench2004
May 29, 2004 04:22 PM
