Interesting pyrometer question
Old Sep 13, 2009 | 01:36 PM
ebteckx's Avatar
So fall is officially here as my grid heaters kicked on for the first time this morning. When I turned the truck on the initial cycle of the grid heaters kicked my pyro to 1500 degrees and then it came back down to its normal 300-350 degree idle temp. Drove the truck and everything was normal so what in the world may have caused that???
Old Sep 13, 2009 | 02:06 PM
madhat's Avatar
Administrator/Jarhead
A bad connection would be my first thought. I'd clean all the connections and re-tighten them.
Old Sep 13, 2009 | 02:51 PM
Where is the pyro grounded?
Old Sep 13, 2009 | 04:11 PM
ebteckx's Avatar
well it goes to the control box, and then grounded under the dash... to the park brake assembly. sorry had to think about that one a minute
Old Sep 13, 2009 | 04:49 PM
Check your main body ground.
Old Sep 13, 2009 | 06:14 PM
Richie O's Avatar
366 Spring Chicken
Any power spike or draw will cause the pryo to do wierd stuff. I had to ground mine directly to the battery to get rid of flutter.
Old Sep 13, 2009 | 06:43 PM
archer39's Avatar
me too.
Old Sep 13, 2009 | 07:10 PM
dzl_damon's Avatar
The pyro is reading a very fine voltage. If there is poor grounds or too small, when a big load goes to teh same grounded part, the voltages will change since ground is usually reference for 0.
Old Sep 13, 2009 | 07:29 PM
ebteckx's Avatar
Okay so I will check that. I have grounded the regulator to the block with big heavy cable I still have to do engine to frame and I also have to replace my negative battery cable. Thanks guys I'll let you know what happens it will be a few days before I have the chance to work on mine again.
Old Sep 13, 2009 | 09:26 PM
Power Ram 250 C's Avatar
More than likely it's a ground. I grounded my pyro under the dash with my other grounds for my other gauges but the pyro was the only one to act up. Ran the ground for the pyro right to the negative post on the battery and works perfect. Amazing what a bad ground can do.
Old Sep 13, 2009 | 09:39 PM
ebteckx's Avatar
Ive seen ground issues cause all sorts of funky problems... I dont know why I didnt think of that right off the bat
IH8MYCAT
Mar 15, 2005 07:23 PM
dodgedude361
Nov 18, 2004 10:44 PM
GaCamper
Nov 27, 2003 03:13 AM
GaCamper
May 13, 2003 06:09 PM
