Inside Front Tire Wear
Old Mar 1, 2010 | 03:07 PM
mhuppertz's Avatar
Hey guys!
So is inside tire wear most likely a worn kingpin?
Mark
Old Mar 1, 2010 | 03:17 PM
On only one tire?
Old Mar 1, 2010 | 03:19 PM
mhuppertz's Avatar
Yes, just the left front. That's wht I was kinda thinking king pin. I'm going to put a new set of tires on and don't want to waste them!
Note: I do have a broken spring pack in the left front. The pin that goed down through the middle is sheared. There doesn't seem to be a lean to the truck though....
Old Mar 1, 2010 | 03:23 PM
Yup, king pin.
Old Mar 1, 2010 | 03:24 PM
mhuppertz's Avatar
I'll look it up replacement in the FSM. Thanks.
Old Mar 1, 2010 | 07:37 PM
stackx2's Avatar
hey wanadiesel mine is doing the same thing as mhuppertz's but i just rebiult my whole kingpin assemblys a year ago do you think that its the same verdict
Old Mar 1, 2010 | 07:54 PM
grouch's Avatar
Check your tie rod ends.
Old Mar 1, 2010 | 08:52 PM
huntinguy's Avatar
Sounds like kingpins. I just ordered a set for my truck.
Old Mar 1, 2010 | 09:53 PM
mhuppertz's Avatar
Just curious, did you get it aligned after you replaced the kingpins?
Old Mar 1, 2010 | 11:16 PM
stackx2's Avatar
no i didnt i measured the tie rod length and put it back to the same as it was when i started and i replace every ball joint and the drag link a month ago
Old Mar 2, 2010 | 06:50 AM
sgreen3's Avatar
That is a deffinate camber issue, so a king pin would be culpret
Dave88LX
14
Sep 1, 2011 11:36 AM
Diesel Head
May 26, 2011 01:47 AM
Southern Pride
Dec 26, 2005 08:32 AM
manureman
Aug 8, 2004 10:02 PM
mountainoiler
May 24, 2004 07:36 AM
