Inside door handle won't work
Old Nov 28, 2013 | 10:24 PM
JimmieD's Avatar
Hi guys!
My '90 W-350 had much abuse being a former 'Gubment' truck. The other day I got in and closed door as usual and when I went to open it from inside - no go! Rolled down the window and let myself out.
Pulled door panel and found that Ma Mopar used a metal rod from inner door handle lever mechanism running across to the latch at door edge. Pure genius, they use some screwy little plastic clips to keep the rod in place at both ends - broken. Very little room to get in there and work on it plus this truck's door had a really hokey repair in the past. Metal had torn and a patch panel was pop riveted in place!
Anyways, I wanted the easy way out. Drove to the local hardware store and bought a coil spring about 1/2" OD and maybe 6"-7" long, fairly stout tension. Attached one end of that spring around the door handle rod and the other end of spring I attached to a hole in the door once spring was stretched out some. This causes constant tension downward on the rod so it keeps it from popping out of the hole in door handle lever mechanism.
Cheap, easy, expect it to last a long time, no more funky plastic clips. Thought I'd pass it along if it could help the next guy...
Old Nov 29, 2013 | 02:50 AM
Jim Lane's Avatar
The plastic clips are available from HELP or Dorman from most any Auto Parts.
Just wait until the screw works it way out from above the door handle and holds you prisoner you inside your truck.
https://www.dieseltruckresource.com/...d.php?t=218946
Deezil
14
Mar 29, 2014 08:10 AM
Apocalypse
Jul 1, 2008 12:09 PM
cheese4420
Apr 13, 2008 11:50 AM
sawboywv1
Sep 26, 2003 09:22 AM
clifford
Aug 7, 2003 09:50 AM
