Injector removal help...
Old Mar 31, 2014 | 05:59 PM
Diesel Jeff's Avatar
I'm trying to remove my injectors from 91.5 Intercooled D250. I removed the injector line, and return line, and the 15/16" clampdown nut. I am having the hardest time removing the injectors from this point. Please share how to get these out. Thanks for all ideas. -Jeff
Old Mar 31, 2014 | 06:12 PM
I have cut down a piece of copper pipe, put a fender washer on top of it and used a 2nd gen lug nut to screw into the top of the injector.
The lug nut pushes against the fender washer that is spaced off the block using the inch or so piece of copper pipe.
Old Mar 31, 2014 | 07:56 PM
BCRick's Avatar
Check the stickies under engine. Look for easy injector removal tool.
Old Apr 1, 2014 | 10:57 AM
peckens's Avatar
1st gen lug nuts are the same thread as well.
I used a 3 3/4" metal conduit pipe and grinded down an old spare lug nut. I recommend going that long so the engine lift bracket isnt in your way.
Also, you should be using metric tools not standard.
Old Apr 1, 2014 | 03:51 PM
93-12Smoke's Avatar
I use a lug nut and a slide hammer.
Old Apr 1, 2014 | 10:18 PM
Jim Lane's Avatar
Here is the injector puller that I made.
Using a Metric Lug Nut and threaded rod.
The 3/4" Black Gas Pipe sleeve is 4" long.
I also have a sleeve that is 3" long to pull the front injector.
The injectors slid out with no resistance.
My truck is a 1991 non-intercooled.
Jim
Old Apr 2, 2014 | 10:29 AM
rrgrassi's Avatar
It looks like the injectors are screw in/out type. Why is a puller needed?
On my MB, you just remove the injector lines, and loosen and remove the injector like you would a spark plug on a gasser.
Old Apr 2, 2014 | 10:48 AM
Rick 12v CTD's Avatar
Because they aren't scree in/out. The 24mm nut holds the injector in place and puts the pressure on the nozzle face to the head sealing it. The little ball on the injector body clocks the injector in the right spot.
Basically it's just a pressure fit with the injector retainer nut. And you need some sort of pulling tool to free it up to slide out once you remove the retainer nut
Sent from my SGH-I747M using Tapatalk
Old Apr 2, 2014 | 01:27 PM
comotionman's Avatar
I would be careful with using the correct lug nut thread should be m12-1.5 on the injector.
The puller is needed as a bit of carbon buildup causes them to stick in the bore.
Old Apr 2, 2014 | 04:44 PM
rrgrassi's Avatar
The threaded portion below the 24mm nut is what confused me. It looked like a screw in/out type.
Thanks for the info!
Cummins Freak
Dec 14, 2007 12:22 AM
M1AM14SPUR
Oct 13, 2007 07:20 PM
mkrenn
Feb 24, 2006 01:12 PM
kawi600
Jan 26, 2006 10:19 AM
GreyBoy
Oct 22, 2003 06:12 PM
