Injector removal help
Old Feb 24, 2006 | 07:47 AM
mkrenn's Avatar
My son is trying to remove the stock injectors and replace the nozzles. He says that they will not pop out. Anyone have any suggestions? Thanks.
Old Feb 24, 2006 | 08:07 AM
Andy505's Avatar
you have to unscrew all the injector lines from the head and move the injector tubes out of the head about 1/2 inch or so, you can just pop out with a screw driver. Then screw one of the bolts for the air plenum (which must be removed as well to get injector #2 out) take one of those bolts and screw it into the top of the injector and pry the injector out...it should come out pretty easy and if it doesnt then something is wrong
Old Feb 24, 2006 | 08:16 AM
mkrenn's Avatar
Thanks. We'll give it a try.
Old Feb 24, 2006 | 08:17 AM
Ocmechanx's Avatar
If I remember corectly the valve cover bolts screwed into the top of my injectors, then I took a pair of vice grips so it gives ya somethin to pry off of.
Just make for sure that you go ur injector tubes out far enough as not to damage them
Bryan
Old Feb 24, 2006 | 08:27 AM
Mike D's Avatar
http://www.lib.uaa.alaska.edu/~tibor...structions.pdf
Old Feb 24, 2006 | 01:12 PM
mkrenn's Avatar
Thanks again!
rock crawler
Dec 27, 2008 12:52 AM
Cummins Freak
Dec 14, 2007 12:22 AM
M1AM14SPUR
Oct 13, 2007 07:20 PM
kawi600
Jan 26, 2006 10:19 AM
GreyBoy
Oct 22, 2003 06:12 PM
