Injector install ??'s
Old Dec 26, 2007 | 05:11 PM
77machomopar's Avatar
I got POD injectors today and what are the rubber boots that came with them for? Also i got thenon-i/c spacers so what washers do i use? only the spacer and thick washer?, spacer and thin washer?, or the washer that is already on the injector and spacer? thanks, i have all of the stockers out so i need to get these in ASAP.
Old Dec 26, 2007 | 05:35 PM
pulltilbroke's Avatar
Best Paint (Getrag category)
When I put mine in I just used the spacer no washer not sure what the boots are for though
Old Dec 26, 2007 | 07:46 PM
I put the injectors in. i took the old ones out by mkaing that tool in the sticky. edit does that tool do a good job. and now all of the injectors are leaking except #2 they seem to be leaking at the head through the plastic retaining nuts. Why they use plastic i dont know but thats where they are leaking. Any suggestions?
Old Dec 27, 2007 | 04:18 PM
Anyone have any suggestions? There are plenty of POD users.
Old Dec 27, 2007 | 04:25 PM
Ilikebikes's Avatar
Try pulling them out, cleaning the copper washers and the surface where they sit against the head and the injector. My #6 was leaking when I put my EDMs in, so I just cleaned both surfaces well and it sealed up just fine.
I don't know what plastic nut you're talking about.
gomerpile's Avatar
well i just got dun doing an injector install myself, and what plastic retaining nut are you talking about, unless the pods come with something weird. i know mine , which where from brazil, had metal retainers. you might want to see if the stock ones will fit, also try tightening all the bolts on the injector,(top line, banjo bolt, retainer)
Old Dec 27, 2007 | 04:32 PM
My pods had steel retaining nuts and I think you have to take the top of the injector apart on the pods to get the retaining nut off
Correct me if I'm wrong
gablekevin
Sep 19, 2006 12:12 AM
kawi600
Jan 26, 2006 10:19 AM
G-NOTE
Sep 1, 2005 06:36 PM
oscaroc
Apr 2, 2005 12:14 PM
