intake heater wont work
Old Dec 19, 2007 | 07:50 PM
cabtruck's Avatar
i have a 91 w350 the intake heater is not working checked the solenoids it is good i dont no how to check the timer but the wate to start light does work what controls it or is there something bad to go out
Old Dec 20, 2007 | 06:36 PM
Intercooled or non-intercooled? The controllers are totally different.
How did you check the solenoids?
Old Dec 20, 2007 | 10:07 PM
Boatnik's Avatar
I took mine out this summer and so far I haven't missed them.
Old Dec 20, 2007 | 11:15 PM
cabtruck's Avatar
it has a intercooler i ran a jumper to the bat and can make it work just cant get it to work from inside
Old Dec 20, 2007 | 11:52 PM
Bill Tomlinson's Avatar
I am kind of a hacker so I would just hook up a manual switch and forget all the automatic crap. If it is below freezing, I would use the heaters. Sometimes, when it is really cold it would be better to have a manual switch than to have to wait while the heaters recycle. Sure would fix the voltage fluctuation
Just don't forget to switch it off or you could burn out the grid heater.
Old Dec 21, 2007 | 04:45 PM
cabtruck's Avatar
well Im dont wont to hack on my truck i wold like it to work the way it is suppose to work
Old Dec 21, 2007 | 04:48 PM
When the WTS light comes on before a cold start (engine temp below 50 f), do you get a 20 second light or just a quick "bulb check" light?
Old Dec 22, 2007 | 10:24 AM
cabtruck's Avatar
the light dont stay on 20 second just 3 or 4 second at the most
Old Dec 22, 2007 | 11:39 AM
Replace the air temp sensor.
Old Dec 22, 2007 | 11:52 AM
cabtruck's Avatar
is that the sender on the intake with two wires ?
Old Dec 22, 2007 | 11:57 AM
One of them. You want the one closer to the front, the back one is the KSB switch.
Old Dec 22, 2007 | 12:15 PM
james1's Avatar
My air intake heater is working but seems to be cycling far more rapidly than it should (or than it used to). Is this also a symptom of a bad intake sensor?
Old Dec 22, 2007 | 12:36 PM
No. The PCM only looks at the air temp when you first turn the key on, from there on the info is ignored on our primitive old system. If the grids turn on on a cold start and don't turn on on a warm start then the IAT is OK.
Is the WTS light flashing?
Old Dec 22, 2007 | 01:25 PM
cabtruck's Avatar
i changed the censor with another truck that works did not help my truck
Old Dec 22, 2007 | 02:33 PM
james1's Avatar
No, the WTS light is working perfectly and the heaters come on fine (for about 20 seconds) when I start the truck cold in the AM. From there until the truck warms up the heaters seem to cycle about every 5 seconds.
