Injector Help
Injector Help
Does anyone know where to get a set of injectors above 150hp for the first gen trucks. I have seen sets on the net but they say 92-98.5. I know that there are a lot of differences in the injectors. And the biggest is the pop pressue and they take a smaller fule line.
POD's can set you to nearly 400HP with supporting air and LP mods. What are you looking for? EDM's or what? I am going to have 6X.015's cut for me. I think that this is where you should go>http://www.neweradiesel.com Chuck is very smart with the injector stuff. You'll need a turbo and fuel support to use the 435's, I promise.
On Edit: What kind of EGT's do you see now? I seen the housing you're runnin is a 12. Just curious beeins it's an auto.
not sure on the egts still havent found a gauge pod that i like prolly going to build my own out of aluminum this weekend. got a single pod for boost and im only running 27 psi thats what the waste gate is set at. Ordered a new housing for cummins. 14cm wastgated housing, should be in friday then im gonna get the pyro installed when i put it on.
TJ0993
11-08-2007 10:27 AM
gablekevin
09-19-2006 12:12 AM
kawi600
01-26-2006 10:19 AM
oscaroc
04-02-2005 12:14 PM
