Injection Pump Tuning
Old Jan 8, 2011 | 07:23 AM
that_guy's Avatar
I'm gonna go out today and rotate the fuel cone, adjust the smoke screw, and try to advance the timing by an 1/8''. None of this is gonna put my engine at risk or being a runaway is it? I just figured these are some small things I could do to get a little more power and MPG's.
Thanks guys and gals.
Advance timing:http://www.youtube.com/watch?v=_U997AFBINk
Fuel Pin:http://www.youtube.com/watch?v=6zPnj...eature=related
Adjust pedal linkage:http://www.youtube.com/watch?v=uKKSD...eature=related
Old Jan 8, 2011 | 07:54 AM
G1625S's Avatar
Nope, no chance of runaway untill you mess with the full fuel screw. Good luck and enjoy your new power
Old Jan 8, 2011 | 08:39 AM
that_guy's Avatar
What other little tweeks are there for the injection pump?
Old Jan 8, 2011 | 08:57 AM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
power screw and grind the deep part of the fuel cones ramp even deeper. those are both free mods.
get a 366 spring from Bosch.
also you can remove the "high idle screw". its the threaded rod thats used as a throttle stop. then you need to shim the "gas pedal" so you get full throttle travel when youre driving.
Old Jan 9, 2011 | 09:13 PM
that_guy's Avatar
Well I did the smoke screw and the fuel pin and throttle linkage. Honestly, I don't see anything special. The EGT's are a little higher, boost is a little higher, I finally see smoke when I floor it but still not much at all. A little poof. That's about it guys. Any more little bits of help?
Old Jan 9, 2011 | 09:19 PM
when i did those mods i didnt see much besides a little more smoke and touchier throttle. time to learn about the fuel screw.
Old Jan 9, 2011 | 09:50 PM
12valvin's Avatar
Take the washer completely off the cone too. And run down your starwheel. I did all these mods, straight piped, and removed my air box and I could tell much quicker spool and some more power. But I bottomed out the smoke screw and start wheel.
Im waiting for gauges and lift pump till I touch my fuel screw
Old Jan 9, 2011 | 10:02 PM
that_guy's Avatar
the washer? on top aginst the rubber part? and is it safe to bottem out the smoke screw and the star wheel? This is still my dd and only wheels. What is this fuel screw I have seen thrown around?
Old Jan 9, 2011 | 10:06 PM
My opinion for what its worth-
The washer can be sanded to about 1/2 its thickness for best performance with stock pin if i remember correctly.
I would leave the smoke screw stock. It doesnt help power.
The power screw/fuel screw is where the power is hidden with the VE pump. You need to be careful when you turn it though because theres a chance the pump will "runaway" and rev uncontrollably. You should search the topic and become familiar with the fuel screw procedure and if youre uncomfortable with turning it you should ask questions then.
Zeb Christensen
Nov 12, 2014 06:21 AM
tommurray
Feb 23, 2014 10:38 AM
12V_shooter25
Oct 21, 2012 11:24 PM
12V_shooter25
Oct 19, 2012 05:02 PM
Spooler
Jul 21, 2009 03:37 PM
