injection pump
I knew you were kidding, cause nobody knows what's in MMO. I quess that's why they call it Mystery Oil
. For some reason, the gasket seeped coolant up near the very front, right edge of the block near the t-stat housing. The mechanic said there was nothing wrong with the head or block, the gasket just didn't get a proper seal when it was assembled and prematurely failed. I had heard at one time that around 92 Cummins did have a run of faulty head gaskets. So I could have gotten one with a bad gasket or the previous owner overheated the engine at some point. But all is well and torquey now.
If you look at the gasket, there is a coolant passage right there in the corner, with not much of a sealing bead around it.
Originally posted by large_marge
i burn my old engine oil. so far, so good.
This is what I do with the waste oil from my CTD https://www.dieseltruckresource.com/...sort/1/cat/500
tommurray
Feb 23, 2014 10:38 AM
billygoat02
Dec 29, 2005 11:03 PM
adgr71
Nov 28, 2005 07:34 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
