ignition switch
Old Aug 17, 2009 | 11:06 AM
steve1988's Avatar
ignition switch
Crancked my truck this morning fine, got back home turned it off just fine. Got back in it to go to work went to crank it and the key just goes forward til the stop with no tension at any point(so it wont turn over). Long story short is there a rod or something that may of come loose or is it time for a new switch?
Old Aug 17, 2009 | 11:26 AM
faylorz's Avatar
i had a 91 ford and the same thing happenned. turned out that some levers and rods broke in the steering column. in my case it wasnt the actual ignition switch but some levers and rods
Old Aug 17, 2009 | 12:01 PM
steve1988's Avatar
Kinda what i thought but wasnt sure. I'm at work now so wont be able to tear into it till about 8. thanks for the fast response.
Old Aug 17, 2009 | 01:09 PM
torquefan's Avatar
I've seen that happen several times and it's generally NOT the ignition switch, but the lock cylinder. There's a cam on the end of it that meshes with the ignition switch, and that cam breaks. It's only available with a lock cylinder package.
Old Aug 17, 2009 | 02:48 PM
steve1988's Avatar
What's involved with changing the switch out? Do I need any special tools or is it a pretty straight forward simple hand tool job ?
Old Aug 17, 2009 | 02:54 PM
Philip's Avatar
You just need some torex bits. The dealer can rekey the new lock cylinder to your old key.
Old Aug 17, 2009 | 02:57 PM
steve1988's Avatar
Thanks for the help guys. All the dealers are closed around here now so gonna have to figure something out, but I'll cross that bridge when I get there. Can't tell you guys enough how much I appreciate all the help.
Old Aug 17, 2009 | 05:21 PM
BearKiller's Avatar
Were it me, I would eliminate all that column mess and move all of the functions into the dash.
The last two winters, my Ford has been warning me that something could go haywire in the key-switch; so, I have been getting all of my ducks in a row to just bypass the whole mess.
Old Aug 17, 2009 | 05:59 PM
What he said. Mine broke like that and so did cfarmer's.
Old Aug 17, 2009 | 06:00 PM
A locksmith can rekey it too. Usually costs more than the stupid cylinder did.
Old Aug 18, 2009 | 11:16 AM
torquefan's Avatar
I've always rekeyed my own, but they're pretty finicky. You need a steady hand, and good eyes and lots of patience if you happen to drop one of those tiny little springs on the floor.
Old Aug 18, 2009 | 01:03 PM
steve1988's Avatar
Got it fixed, changed out the little cylinder for $16. Honestly I'm too lazy to to mess with the key so now I have a door key and an ignition key .Thanks again for all the advice guys.
Old Aug 18, 2009 | 04:57 PM
Me too.
Cowhand
Sep 21, 2004 10:42 AM
jman
Aug 25, 2004 05:15 PM
jd03ctd
May 10, 2004 08:06 AM
GaCamper
Dec 1, 2003 08:59 PM
D4Fritz
Mar 16, 2003 03:55 PM
