idle help
idle help
my idle is set pretty high with my FF set pretty close to runaway and other mods, i dont havce anymore room to turn it down my screw is backed all the way out being completly useless and i want my idle down about 100 any ideas or suggestions??
1st Generation Admin
Go to the linkage that connects the throttle bellcrank to the IP. You'll notice that the threaded rod that connects to two ends is threaded such that you can loosen the jamb nuts at each end, and then turn the center rod to make the assembly longer or shorter.
You need to adjust yours till the idle comes down to what you want.
While you're at it, have someone hold the pedal to the floor and you make sure the throttle is going full stroke. Adjust the linkage accordingly.
Hope this helps.
Hope this helps.
Ram1999
02-11-2007 10:49 AM
pet05
10-05-2006 11:02 AM
dieselnewbie
01-18-2005 10:48 PM
