Idle adjustment after fuel screw twist
I recently adjusted the fuel screw on my 92, and I'm having an issue with the idle speed. I turned the fuel screw in one turn, found the idle speed to be too high. So I backed out the idle screw, but I couldn't get the idle back down to normal. I ended up backing the fuel screw out to the stock position(back out 1 turn) and the idle is back to normal. However, when I rev the engine up to higher rpms and immediately let off the throttle, the rpm's drop down very low(almost kills the engine), and then the engine comes back up to idle speed. Has anyone else experienced this problem after tampering with their injection pump? If so, does any have any suggestions on how to fix this problem, or has anyone been successul in doing so?
Thanks,
Dawson
Thanks,
Dawson
A few pointers:
Was the throttle lever touching the idle screw? Often the trans linkage or the bellcrank keeps the throttle lever from contacting the idle screw. The linkage will have to be adjusted to compensate if this is your problem.
It sounds like the throttle lever is not clocked correctly, that's the usual cause of a droop and recovery. Have you had the throttle arm off for any reason?
Check the info here.
http://www.dodgeram.org/tech/dsl/mor...r/Power_ve.htm
Standing on a box at the front of the truck, looking down on the idle adjustment screw & locknut..I loosened the idle speed screw locknut with a punch and small hammer by tapping the right side of the locknut flats. After setting the idle speed, I tightened the locknut by punching the left side of the locknut
A few pointers:
Thanks,
Dawson
Thanks,
Dawson
No, I'm talking about the lever on the pump. If you haven't taken it off then it should be fine, but when guys swap governor springs it's very common to wind up one tooth off on the throttle shaft.
Thanks,
Dawson
jmd4993
Jun 22, 2013 07:36 AM
FlaCracker
Oct 23, 2009 02:42 PM
