I put in the 4" exhaust and HX35...Lost Boost and low end power...
Old Aug 7, 2004 | 08:49 AM
Jim Shulmister's Avatar
Muted User
O and FYI, The amount of turbo boost is determined by the differential of temperature on the hot (Exhaust manifold) and cool (exhaust pipe) side. The temperature on the output side is lowered by adding the higher flow pipe, which also increases (reletively) the higher boost/lower temps of the exhaust manifold side.Adding fuel increases the manifold temperature. You have the larger injectors, even if you had a low fuel output at low rpm, you should be KILLING the boost numbers at WOT.YOU HAVE A LEAK. And since it happened at the install if the new turbo check there first.
Possibly if you have the 60mm impeller installed on your hx35 you would have a lower bottom boost, but top boost should still be higher.
-Jim-
03RAMBUNCTIOUS
Nov 17, 2009 03:22 PM
browndg
Dec 15, 2008 05:58 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
notomas
25
Sep 10, 2007 05:05 PM
spitzair
Jan 24, 2006 03:42 PM
