I.p.rebuild Pictures
Old Mar 1, 2008 | 01:31 AM
BearKiller's Avatar
Arrow I.p.rebuild Pictures
I found this :
http://www.vwdieselparts.com/forum/viewtopic.php?t=6694
Is this procedure similar to ours ??
Does anyone have a link to a similar write-up/pictures on our pumps ??
Thanks.
Old Mar 1, 2008 | 05:07 AM
Chrisreyn's Avatar
nice find...
i had a link to a FSm for the VE pumps that showed diagrams similar to this. I'll dig around and see if I can find it again.....
Old Mar 1, 2008 | 05:45 AM
Yes, same basic pump.
Old Mar 1, 2008 | 10:19 AM
Alec's Avatar
That is what I read before I put new seals in my pump. It is close enough to get the job done. If I had found that some hard parts were toast inside, I would have had to go to a pump shop, but my pump was pretty good inside, and I got to tweak the torque curve on the engine a little bit while I was in there. I posted about the operation about a year ago. The truck is still running well.
Old Mar 1, 2008 | 04:39 PM
BearKiller's Avatar
I also found this :
http://forums.tdiclub.com/showthread.php?p=437307
Note the link to a source for downloading a Bosch manual.
Old Mar 5, 2008 | 06:45 PM
BearKiller's Avatar
Wink Just tying things together
Stillsmokin's VE thread :
https://www.dieseltruckresource.com/...d.php?t=172432
Captain Chrysler's VE thread :
https://www.dieseltruckresource.com/...d.php?t=195143
And, check out these VIDEOs of VE pumps in action :
http://www.youtube.com/watch?v=_r6RN7vQmXw
Old Mar 16, 2008 | 07:23 PM
BearKiller's Avatar
Wink Here Is Another Good One
http://pics.tdiclub.com/data/3555/Bo..._pump_head.pdf
I am assuming that where these four-cylinder pumps have four slots in the pump-shaft, four humps in the cam-plate, four rollers, and a four-notched cross, etc., our pumps should have SIX, RIGHT ??
Here is a picture of the "crow-foot" that the sticky says we need for line removal :
http://buy1.snapon.com/catalog/item....store&tool=all
And here is the weird-looking flare-nut-socket :
Old Mar 17, 2008 | 11:16 AM
Alec's Avatar
Our pumps only have four rollers -- they just aren't evenly spaced at 90 degrees as are the 4 cyl. version -- that the six cam humps ride on. Otherwise, you are right on.
I have neither of those special tools, BTW. The only special tool I think is necessary is the S-wrench to get to that stupid bottom nut on the IP to timing case flange.
To remove the three sided "tamper resistant" Bosch hardware, I use a 12pt socket with solid copper wire jammed in it to grab the three-sided head. I had intended to grind out a 6pt socket to make a special tool, but the copper wire worked well.
Old Mar 23, 2008 | 06:37 PM
BearKiller's Avatar
Post More Pump Info
Another pump thread :
https://www.dieseltruckresource.com/...d.php?t=197882
Here is a good one showing re-sealing a leaking control-valve, along with exploded diagrams :
https://www.dieseltruckresource.com/...d.php?t=124850
ALEC's pump thread with some good things to look out for :
https://www.dieseltruckresource.com/...d.php?t=138295
And here is a real good one = 66-pages all about the VE; click on the link, then click on where it says "attached file" :
http://www.cumminsforum.com/forum/31845-post7.html
Thanks to sdstriper, I bought this DVD/book set that is well worth the fifty-bucks :
http://www.youtube.com/watch?v=oYttzGdKgM0
And here is a link to the book/DVD set on E-BAY :
http://cgi.ebay.com/ebaymotors/Diese...QQcmdZViewItem
Old Mar 23, 2008 | 10:52 PM
daking's Avatar
has anybody bought the ebay books an cds, they seem quite good, ive seen parts of them on youtube
Old Mar 30, 2008 | 09:09 AM
BearKiller's Avatar
Question Difference In Pumps ??
According to this source, there are two seperate 1st Gen. injection pumps.
VE205 on intercooled.
VE184 on non-intercooled.
http://www.dieselcare.net/DODGEPRODUCTS.html
How do they differ ??
What would be the outcome of switching them between engines ??
For instance, a 205-pump is installed where a 184-pump was original, or vice-versa.
Thanks.
MORE PUMP THREADS :
BUSHY's VE-pump RAMBLINGS :
https://www.dieseltruckresource.com/...ad.php?t=23985
Tuning "smoke" screw :
https://www.dieseltruckresource.com/...ad.php?t=22841
Old Mar 30, 2008 | 09:45 AM
The throttle levers are slightly different, the AFC lever pivot pin is retained by different methods, the fuel screw has a hex head on the 205 pump, and the delivery valve holders are longer on the 184 pump. They are interchangeable for all practical purposes. I have a 184 top on my 205 pump.
Old Mar 30, 2008 | 09:55 AM
BearKiller's Avatar
Can it be determined which pump by looking at the identification-plate on the pump-body ??
Will it say 184 or 205 ??
Thanks.
Old Mar 30, 2008 | 10:02 AM
Yes, it is part of the ID code.
Old Mar 30, 2008 | 12:37 PM
dieselJon's Avatar
Can I recommend a sticky? This is good stuff! I am going to start the quest for a Hot Rod VE as soon as I get the pump I sent a check out for yesterday
Thank You bearkiller! You da best!
Jon
